In general my weather webview works normally.
However sometimes I get the Error instead of the forecast:
HTTP Error 500
Weather locationId ‘home’ does not exist.
In my openhab.log I find:
2016-01-13 12:50:36.882 [WARN ] [e.jetty.servlet.ServletHandler] - /weather
javax.servlet.ServletException: Weather locationId 'home' does not exist
at org.openhab.binding.weather.internal.gfx.WeatherServlet.doGet(WeatherServlet.java:111) ~[na:na]
In most cases a powerdown for some time solves the issue.
I have read some posts here, but their problem obviously based on a wrong configuration without any ‘home’ item.
I this a know issue, that it’s sometimes working and sometimes not?
Does nobody else have this issue?
I have read some similar problems related to SD-cards not working properly.
So might this be the issue?
If the SD-card quality is the issue, what kind of Raspberry or similar can be recommended with sufficient integrated memory!?
I did not pay attention a while because I had other problems
But it’s still not reliable.
Every now and then I still get the same message:
/weather
javax.servlet.ServletException: Weather locationId ‘home’ does not exist
Even on 1.8.3 it’s still there…
It’s weird that it works sometimes and sometimes not - without any changes.
It’s still there.
I restarted 1.8.3 a few times to make it work (no config changes in between) and webview ist working fine for now. Let’s see how long it takes until it’s messed up again.
I wonder why it’s obviously not working out of a sudden without touching the config!?
