I’m not sure when it happened, but I noticed that my weather1 binding html image is not longer giving me information for the future forecasted days. It shows the current day correctly, but not the forecast.
This is the full html, and do not think anything has changed on it so unsure why just the forecast items do not work.
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-type" CONTENT="text/html; charset=utf-8">
<link rel="stylesheet" type="text/css" href="static/weather-data/layouts/example.css" />
<script type="text/javascript" src="static/weather-data/layouts/example.js"></script>
</head>
<body id="weather-body" onload="formatIframe()">
<div id="weather-location-name">${config:name}, ${weather:condition.observationTime(%1$td.%1$tm.%1$tY %1$tH:%1$tM)}</div>
<table id="weather-table">
<tr>
<td rowspan="2"><img id="weather-icon" src="static/weather-data/images/${param:iconset}/${weather:condition.commonId}.png"/></td>
<td id="weather-temp">${weather:temperature.current(%.1f)[fahrenheit]}</td>
<td id="weather-temp-sign">°F</td>
</tr>
<tr>
<td colspan="2">
<table id="weather-table-details">
<tr>
<td>Humidity:</td>
<td>${weather:atmosphere.humidity} %</td>
</tr>
<tr>
<td>Pressure:</td>
<td>${weather:atmosphere.pressure(%.1f)} mb</td>
</tr>
</table>
</td>
</tr>
</table>
<table id="weather-forecast-table">
<tr>
<td>Today</td>
<td>${forecast(1):condition.observationTime(%1$tA)}</td>
<td>${forecast(2):condition.observationTime(%1$tA)}</td>
<td>${forecast(3):condition.observationTime(%1$tA)}</td>
<td>${forecast(4):condition.observationTime(%1$tA)}</td>
</tr>
<tr>
<td><img src="static/weather-data/images/${param:iconset}/${forecast(0):condition.commonId}.png"/></td>
<td><img src="static/weather-data/images/${param:iconset}/${forecast(1):condition.commonId}.png"/></td>
<td><img src="static/weather-data/images/${param:iconset}/${forecast(2):condition.commonId}.png"/></td>
<td><img src="static/weather-data/images/${param:iconset}/${forecast(3):condition.commonId}.png"/></td>
<td><img src="static/weather-data/images/${param:iconset}/${forecast(4):condition.commonId}.png"/></td>
</tr>
<tr>
<td class="temp-max">${forecast(0):temperature.max(%.0f)[fahrenheit]}</td>
<td class="temp-max">${forecast(1):temperature.max(%.0f)[fahrenheit]}</td>
<td class="temp-max">${forecast(2):temperature.max(%.0f)[fahrenheit]}</td>
<td class="temp-max">${forecast(3):temperature.max(%.0f)[fahrenheit]}</td>
<td class="temp-max">${forecast(4):temperature.max(%.0f)[fahrenheit]}</td>
</tr>
<tr>
<td class="temp-min">${forecast(0):temperature.min(%.0f)[fahrenheit]}</td>
<td class="temp-min">${forecast(1):temperature.min(%.0f)[fahrenheit]}</td>
<td class="temp-min">${forecast(2):temperature.min(%.0f)[fahrenheit]}</td>
<td class="temp-min">${forecast(3):temperature.min(%.0f)[fahrenheit]}</td>
<td class="temp-min">${forecast(4):temperature.min(%.0f)[fahrenheit]}</td>
</tr>
</table>
</body>
</html>
And a sample of forecast 1
Number Weather_Temp_Min1 "Temperature min [%.2f °F]" {weather="locationId=home, forecast=1, type=temperature, property=min, unit=fahrenheit"}
Number Weather_Temp_Max1 "Temperature max [%.2f °F]" {weather="locationId=home, forecast=1, type=temperature, property=max, unit=fahrenheit"}
