I just set up the WeatherBinding with Openweathermap.
Unfortunately, the precipitation propability does not get set.
When I look at the API in the response XML it seems to be sent.
Can this maybe be added?
I think right now that value is only supported by Wunderground, and even then at least for me it is broken.
I’ve use the XSLT approach to pull in the precipitation values. I posted how I do that here.
