Hi there,
I recongnized that I never receive any value above 0 for the current rain amount using weatherbit.io (all other value are receiving values as expected).
Item configuration is
Number WeatherRain “Rain [%.2f mm/h]” (gWeather) {weather=“locationId=home, type=precipitation, property=rain”}
I checked the API directly with the example below
{“data”:[{“rh”:80,“pod”:“d”,“lon”:8.53333,“pres”:979.43,“timezone”:“Europe/Berlin”,“ob_time”:“2020-06-05 16:16”,“country_code”:“DE”,“clouds”:100,“ts”:1591373775,“solar_rad”:78.2525,“state_code”:“07”,“city_name”:“Bielefeld”,“wind_spd”:6.29415,“last_ob_time”:“2020-06-05T15:47:00”,“wind_cdir_full”:“west-southwest”,“wind_cdir”:“WSW”,“slp”:991.855,“vis”:24.135,“h_angle”:56.3,“sunset”:“19:40”,“dni”:669.37,“dewpt”:8.2,“snow”:0,“uv”:0.776824,“precip”:3.63158,“wind_dir”:240,“sunrise”:“03:11”,“ghi”:313.01,“dhi”:77.24,“aqi”:49,“lat”:52.03333,“weather”:{“icon”:“r01d”,“code”:“500”,“description”:“Light rain”},“datetime”:“2020-06-05:16”,“temp”:11.4,“station”:“E6958”,“elev_angle”:30.39,“app_temp”:11.4}],“count”:1}
And as you can see there is no item called “rain” but only “precip” that seems to contain the “rain” value (see also documentation https://www.weatherbit.io/api/weather-current).
My assumption is that the internal mapping of the item to the API-call does’t relect this. And there is no item property called “precip” (error is generated).
Anyone who could give an advice how to fix this issue?
Thomas
