Number Weather_Temperature “Temperature [%.2f °C]” {channel=“weathercompany:weather:local:forecastDay0Day#temperature”}
Note that you might need to use the UoM definition to get your data in Metric. If you see the temp in degrees F using this item definition, you’ll need to change it to this.
@mdnx Would you mind running this URL in your browser, then posting the result back here? Just XXXX out anything in the response that you don’t want to put on the forum. Or, just PM it to me.
hi @mhilbush - I had a look though the doc and compared it to the channels in the current Weather Underground Binding . What the Weather Company API offers seems to cover all necessary current observations for use in a SmartHome scenario indeed.
Some values are not provided by Weather Company (such as visibility, dew point or pressure Trend) . However inmho these can be neglected for the use in a Smarthome, as they can either be calculated (dew Point, Pressure Trend) or are not measured by (most of) the PWS - and as such not local and relevant.
Thanks for looking into adding current observations
I’m sorry, but I don’t know how to be more clear about this. The binding currently shows just the weather forecast. Current conditions (as sourced from the data you uploaded from your PWS) is currently not implemented in the binding.
what a cluster this whole EOLing the WU API is… So frustrating. Thank you for starting on this binding. I use an Ambient Weather 2902, and as current conditions access is my primary need, looks like I’ll have to start experimenting with the Ambient Weather binding.
Thanks for making the decision easy for me! And, wow, thank you for also creating the AW binding that it looks like i’ll be enjoying from now on. My sensor array is the 2902, but I opted for the IP Observer (IP1550) receiver because I wanted the unit hardwired to my LAN and really didn’t need the display because I display the weather data of interest on wall mounted tablets running HabPanel. The IP1550 reports to WU and AW both, so I don’t see any issues.
BTW, IBM confirmed your March 22nd date:
Hi Victoria,
I seem to be seeing different EOL dates tossed around, and I have yet to be contacted by WU/WC via e-mail (as I sort of thought I would be - that’s what the original notice says). Can you tell me what day the old API service will actually stop dead in its tracks? Is it March 22nd? Thank You.
All the email efforts went out in late 2018. I’m sorry yours did not manage to find you!
Most of the keys have already been turned off. Keys that are associated with a personal weather station will be kept on until 3-22, at which point they will also be turned off.
Which means, that a minimal 1min Forecast refresh Interval would still be on the safe side (=1440 calls/day). This interval is for sure neither a realistic nor healthy one, but might be of interest in moments, when one is e.g. testing rules etc.
Again - thanks a lot - its fantastic move of your to provide a working binding just hours after the Weather Company API release! In my case, your work, safes me from investing and wasting time with replacement stuff!
