Updated to: openHAB 2.3.0 Build #1231
When you start openHAB2 in the log file the following lines:
2018-03-18 10:00:44.326 [WARN ] [core.audio.internal.AudioManagerImpl] - An exception occurred while setting the volume of sink webaudio : 'Web Audio sink does not support volume level changes.'
java.io.IOException: Web Audio sink does not support volume level changes.
at org.eclipse.smarthome.io.webaudio.internal.SSEAudioSink.setVolume(SSEAudioSink.java:115) ~[?:?]
at org.eclipse.smarthome.core.audio.internal.AudioManagerImpl.setVolume(AudioManagerImpl.java:180) ~[?:?]
at org.eclipse.smarthome.core.audio.internal.AudioManagerImpl.play(AudioManagerImpl.java:115) ~[?:?]
at org.eclipse.smarthome.core.audio.internal.AudioManagerImpl.playFile(AudioManagerImpl.java:144) ~[?:?]
at org.eclipse.smarthome.core.audio.internal.AudioManagerImpl.playFile(AudioManagerImpl.java:124) ~[?:?]
at org.eclipse.smarthome.model.script.actions.Audio.playSound(Audio.java:40) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1085) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1060) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1046) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:991) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:143) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:901) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:864) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:223) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:219) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189) ~[?:?]
at org.eclipse.smarthome.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:82) ~[?:?]
at org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl.lambda$2(RuleEngineImpl.java:339) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
2018-03-18 10:00:46.392 [WARN ] [core.audio.internal.AudioManagerImpl] - An exception occurred while setting the volume of sink webaudio : 'Web Audio sink does not support volume level changes.'
at org.eclipse.smarthome.io.webaudio.internal.SSEAudioSink.setVolume(SSEAudioSink.java:115) [121:org.eclipse.smarthome.io.webaudio:0.10.0.201803161254]
at org.eclipse.smarthome.core.audio.internal.AudioManagerImpl.setVolume(AudioManagerImpl.java:180) [98:org.eclipse.smarthome.core.audio:0.10.0.201803161254]
at org.eclipse.smarthome.core.voice.internal.VoiceManagerImpl.say(VoiceManagerImpl.java:211) [107:org.eclipse.smarthome.core.voice:0.10.0.201803161254]
at org.eclipse.smarthome.model.script.actions.Voice.say(Voice.java:121) [133:org.eclipse.smarthome.model.script:0.10.0.201803161254]
at org.eclipse.smarthome.model.script.actions.Voice.say(Voice.java:69) [133:org.eclipse.smarthome.model.script:0.10.0.201803161254]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1085) [152:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1060) [152:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1046) [152:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:991) [152:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:143) [133:org.eclipse.smarthome.model.script:0.10.0.201803161254]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:901) [152:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:864) [152:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:223) [152:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:219) [133:org.eclipse.smarthome.model.script:0.10.0.201803161254]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203) [152:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446) [152:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227) [152:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189) [152:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) [152:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) [152:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at com.sun.proxy.$Proxy151.apply(Unknown Source) [?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) [133:org.eclipse.smarthome.model.script:0.10.0.201803161254]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [103:org.eclipse.smarthome.core.scheduler:0.10.0.201803161254]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [103:org.eclipse.smarthome.core.scheduler:0.10.0.201803161254]
How can this be remedied?
UPD:
This happens in two cases:
- playSound()
- say()
When I start the system, I get a rule, it causes these warnings
rule "voice"
Item voice_str received update
playSound("doorbell.mp3")
createTimer(now.plusSeconds(2), [|
say(voice_str.state.toString,"voicerss:ruRU")
Thanks!
