- Platform information:
- Hardware: CPUArchitecture/RAM/storage
- OS: what OS is used and which version
- Java Runtime Environment: which java platform is used and what version
- openHAB version:
- Issue of the topic: please be detailed explaining your issue
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
hai,
hai iam working on a project smart home automation in which i want to control home appliances using openhab from web or android phone. so in which iam using relay to to connect the things and iam having problem with the items and sitemaps. iam getting problem which switch not working for the relay to turn on/off.
if any body has the solution please help me to get the output.
Thank u,
