hi to all, after researching all the posts with negative results, I expose my problem.
Yesterday all of a sudden the bticino gateway no longer communicated with hopen hab, I tried to uninstall everything and install open hab on synology with openwebnet latest version but also having entered the right ip with password I get this error
2019-06-15 23:17:14.982 [me.event.ThingUpdatedEvent] - Thing ‘openwebnet:bus_gateway:F454_000350860efa’ has been updated.
2019-06-15 23:17:15.019 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[]]
2019-06-15 23:17:15.125 [hingStatusInfoChangedEvent] - ‘openwebnet:bus_gateway:F454_000350860efa’ changed from OFFLINE (COMMUNICATION_ERROR) to UNKNOWN
2019-06-15 23:17:15.156 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[]]
2019-06-15 23:17:35.167 [hingStatusInfoChangedEvent] - ‘openwebnet:bus_gateway:F454_000350860efa’ changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR)
2019-06-15 23:28:04.983 [hingStatusInfoChangedEvent] - ‘openwebnet:bus_gateway:F454_000350860efa’ changed from OFFLINE (COMMUNICATION_ERROR) to UNINITIALIZED
2019-06-15 23:28:05.032 [hingStatusInfoChangedEvent] - ‘openwebnet:bus_gateway:F454_000350860efa’ changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2019-06-15 23:28:08.113 [hingStatusInfoChangedEvent] - ‘openwebnet:bus_gateway:F454_000350860efa’ changed from UNINITIALIZED (DISABLED) to INITIALIZING
2019-06-15 23:28:08.150 [hingStatusInfoChangedEvent] - ‘openwebnet:bus_gateway:F454_000350860efa’ changed from INITIALIZING to UNKNOWN
2019-06-15 23:28:28.188 [hingStatusInfoChangedEvent] - ‘openwebnet:bus_gateway:F454_000350860efa’ changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR)
I tried to connect to the server with the same credentials through My home suite and everything works I can reprogram and see the gateway with the devices in the field …
any suggestions … thanks and sorry for the length of the post
