OS: ARMBian 5.38 - Linux oh 4.14.15-sunxi #28 SMP Mon Jan 29 07:24:48 CET 2018 armv7l GNU/Linux
Java Runtime Environment: openjdk version “1.8.0_152” - Zulu Embedded 8.25.0.76-linux-aarch32hf
openHAB version: 2.2.0-1
Hello to all.
I’ve installed a fresh board and openhab2. Then I’ve tried to restore the backups from a 2.0 conf.
After correcting some issues (env, path) now the service starts manually in debug mode, but the webserver is not running, no service listening on port 8080. What could be the cause? I’m in the console, but have no idea what to check.
As you can see there is a -Dorg.osgi.service.http.port=8080 but java is listening only here:
root@oh:~# netstat -naop | grep java
tcp 0 0 0.0.0.0:5005 0.0.0.0:* LISTEN 3153/java off (0.00/0/0)
tcp6 0 0 127.0.0.1:43779 :::* LISTEN 3153/java off (0.00/0/0)
tcp6 0 0 127.0.0.1:8101 :::* LISTEN 3153/java off (0.00/0/0)
tcp6 0 0 :::5007 :::* LISTEN 3153/java off (0.00/0/0)
tcp6 0 0 :::8181 :::* LISTEN 3153/java off (0.00/0/0)
udp6 0 0 :::5353 :::* 3153/java off (0.00/0/0)
is there a way to check it from the openhab console?
# ./start_debug.sh
Launching the openHAB runtime...
Listening for transport dt_socket at address: 5005
__ _____ ____
____ ____ ___ ____ / / / / | / __ )
/ __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __ |
/ /_/ / /_/ / __/ / / / __ / ___ |/ /_/ /
\____/ .___/\___/_/ /_/_/ /_/_/ |_/_____/
/_/ 2.2.0
Release Build
Hit '<tab>' for a list of available commands
and '[cmd] --help' for help on a specific command.
Hit '<ctrl-d>' or type 'system:shutdown' or 'logout' to shutdown openHAB.
openhab>
I’ve installed it via apt on an armbian ISO. I’ll try to install OpenHABian then, but my board is not a raspberry. Maybe compatible as well, don’t know. I would like to understood why it’s not working BTW.
Openhab log is near empty:
Jan 30, 2018 5:32:38 PM org.apache.karaf.main.lock.SimpleFileLock lock
INFO: Trying to lock /var/lib/openhab2/tmp/lock
INFO: Lock acquired
Jan 30, 2018 5:32:38 PM org.apache.karaf.main.Main$KarafLockCallback lockAquired
INFO: Lock acquired. Setting startlevel to 100
Hello @Udo_Hartmann
I’ve made some step more. I’ve recovered this file from my 2.0 openhab:
/var/lib/openhab2/etc/config.properties
Now, after correcting the karaf.framework.equinox path to the new one, the webserver starts. BTW seems other modules onthe file are poining on old modules I have on the 2.0 openhab.
Is there a default config.properties to start with?
