- Platform information:
- Hardware: Tinkerboard
- OS: Debian Buster
- Java Runtime Environment: openjdk version “1.8.0_252”
OpenJDK Runtime Environment (Zulu 8.46.0.225-CA-linux_aarch32hf) (build 1.8.0_252-b225)
OpenJDK Client VM (Zulu 8.46.0.225-CA-linux_aarch32hf) (build 25.252-b225, mixed mode, Evaluation) - openHAB version: 2.5.5
After update from 2.5.4 to 2.5.5_01 i get the warning:
[WARN ] [ueemulation.internal.upnp.UpnpServer] - Upnp server: Address test failed
java.util.concurrent.CompletionException: java.lang.IllegalStateException: Could not join upnp multicast network!
at java.util.concurrent.CompletableFuture.encodeRelay(CompletableFuture.java:326) ~[?:1.8.0_252]
at java.util.concurrent.CompletableFuture.completeRelay(CompletableFuture.java:338) ~[?:1.8.0_252]
at java.util.concurrent.CompletableFuture.uniRelay(CompletableFuture.java:925) ~[?:1.8.0_252]
at java.util.concurrent.CompletableFuture$UniRelay.tryFire(CompletableFuture.java:913) ~[?:1.8.0_252]
at java.util.concurrent.CompletableFuture.postComplete(CompletableFuture.java:488) [?:1.8.0_252]
at java.util.concurrent.CompletableFuture.completeExceptionally(CompletableFuture.java:1990) [?:1.8.0_252]
at org.openhab.io.hueemulation.internal.upnp.UpnpServer.accept(UpnpServer.java:448) [bundleFile:?]
at org.openhab.io.hueemulation.internal.upnp.UpnpServer.accept(UpnpServer.java:1) [bundleFile:?]
at org.openhab.io.hueemulation.internal.upnp.HueEmulationConfigWithRuntime.run(HueEmulationConfigWithRuntime.java:111) [bundleFile:?]
Caused by: java.lang.IllegalStateException: Could not join upnp multicast network!
… 3 more
and a additional Info:
2020-05-27 18:17:59.447 [INFO ] [control.internal.WebSocketConnection] - Web Socket error {}
java.nio.channels.AsynchronousCloseException: null
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.close(HttpConnectionOverHTTP.java:181) ~[?:?]
at java.util.ArrayList.forEach(ArrayList.java:1257) [?:1.8.0_252]
at org.eclipse.jetty.client.AbstractConnectionPool.close(AbstractConnectionPool.java:208) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.DuplexConnectionPool.close(DuplexConnectionPool.java:237) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpDestination.close(HttpDestination.java:385) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpClient.doStop(HttpClient.java:260) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.component.AbstractLifeCycle.stop(AbstractLifeCycle.java:93) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.component.ContainerLifeCycle.stop(ContainerLifeCycle.java:180) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStop(ContainerLifeCycle.java:201) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.client.WebSocketClient.doStop(WebSocketClient.java:371) [bundleFile:9.4.20.v20190813]
at org.openhab.binding.amazonechocontrol.internal.WebSocketConnection.close(WebSocketConnection.java:159) [bundleFile:?]
at org.openhab.binding.amazonechocontrol.internal.WebSocketConnection$2.run(WebSocketConnection.java:184) [bundleFile:?]
at java.util.TimerThread.mainLoop(Timer.java:555) [?:1.8.0_252]
at java.util.TimerThread.run(Timer.java:505) [?:1.8.0_252]
can someone explain what to do in Java to fix?
Or what to in Openhab to fix
Regards
Stef
