i have the web Socket error to in OPENHAB 2.5.5-1 disused in
Java heap space…java.lang.OutOfMemoryError
and
Web Socket error {}
now i was pointed to this post. (I closed the other ones pointing them to this posed to bring everything together!)
The error is still there!
See:
2020-06-15 14:06:04.943 [INFO ] [nternal.WebSocketConnection$Listener] - Web Socket error
java.nio.channels.AsynchronousCloseException: null
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.close(HttpConnectionOverHTTP.java:181) ~[?:?]
at java.util.ArrayList.forEach(ArrayList.java:1257) [?:1.8.0_252]
at org.eclipse.jetty.client.AbstractConnectionPool.close(AbstractConnectionPool.java:208) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.DuplexConnectionPool.close(DuplexConnectionPool.java:237) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpDestination.close(HttpDestination.java:385) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpClient.doStop(HttpClient.java:260) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.component.AbstractLifeCycle.stop(AbstractLifeCycle.java:93) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.component.ContainerLifeCycle.stop(ContainerLifeCycle.java:180) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStop(ContainerLifeCycle.java:201) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.client.WebSocketClient.doStop(WebSocketClient.java:371) [bundleFile:9.4.20.v20190813]
at org.openhab.binding.amazonechocontrol.internal.WebSocketConnection.close(WebSocketConnection.java:171) [bundleFile:?]
at org.openhab.binding.amazonechocontrol.internal.WebSocketConnection$2.run(WebSocketConnection.java:200) [bundleFile:?]
at java.util.TimerThread.mainLoop(Timer.java:555) [?:1.8.0_252]
at java.util.TimerThread.run(Timer.java:505) [?:1.8.0_252]
The new jar-file did not help!
And there is a new quality in town: after a periode of time: Openhab crashes with another warning:
2020-06-12 22:56:28.026 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /start/index
java.lang.OutOfMemoryError: Java heap space
2020-06-12 22:56:38.624 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /start/index
So there is a new qualitiy in town!! System crash!!!
Please have a look and help!
Cheers
Stef
