Hello everybody,
I’m using OpenHAB since a few months, but it seems to freeze after an undefined amount of time. I can’t reach the control panel. Nether via intranet or via the cloud service.
My configuration:
Raspberry Pi 4 Model B - 2GB
openHABian with openHAB 3.3.0
At first I did what every beginner does I guess: Just restart it by restarting the Raspberry Pi. Then I found out that I could just restart the service.
But when it kept freezing and I kept restarting I of course wanted to know what could be done about it. I’ve looked into the “status” command and at the moment I can’t reach the webinterface (so when it’s “frozen”), it comes back like this:
A systemd service configuration exists...
Use 'sudo /bin/systemctl status openhab.service' to find the status of an openHAB service
openHAB is running with PID: 2**8 and has been running for 33-22:59:35
Then I tried the suggestion which came back, and use the command as stated above and the following came back:
● openhab.service - openHAB - empowering the smart home
Loaded: loaded (/lib/systemd/system/openhab.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/openhab.service.d
└─override.conf
Active: active (running) since Mon 2022-09-26 11:25:00 CEST; 1 months 3 days ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Main PID: 2**8 (java)
Tasks: 268 (limit: 4455)
CPU: 1d 8h 10min 23.013s
CGroup: /system.slice/openhab.service
└─2**8 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.userdat>
Warning: journal has been rotated since unit was started, output may be incomplete.
As a total beginner to, well everything, I think this means that everything is running OK. Could it just be that the webserver freezes and that’s the reason I can’t connect?
I’ve also checked the logs and the output is as follows:
==> /var/log/openhab/audit.log <==
2022-10-03 23:54:38.949 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Humidifier_RunTime' changed from 14021.316944444445 h to 14021.325277777778 h
2022-10-03 23:54:42.942 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Consuela_Batterijniveau' changed from 72 to 71
2022-10-03 23:54:42.948 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Consuela_Status_Clean_Area' changed from 31.06 to 31.16
2022-10-03 23:54:42.955 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Consuela_CleaningTime' changed from 33 to 34
2022-10-03 23:54:43.460 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Consuela_CleaningMap' changed from raw type (image/jpeg): 22175 bytes to raw type (image/jpeg): 22388 bytes
2022-10-03 23:55:08.902 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Humidifier_RunTime' changed from 14021.325277777778 h to 14021.333611111111 h
2022-10-03 23:55:12.954 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Consuela_Status_Clean_Area' changed from 31.16 to 31.27
2022-10-03 23:55:13.460 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Consuela_CleaningMap' changed from raw type (image/jpeg): 22388 bytes to raw type (image/jpeg): 22380 bytes
2022-10-03 23:55:38.845 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Humidifier_RunTime' changed from 14021.333611111111 h to 14021.341944444444 h
2022-10-03 23:55:42.971 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Consuela_Batterijniveau' changed from 71 to 70
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) [bundleFile:9.4.46.v20220331]
It seems like the last thing it did was some status-change on 10-03-2022 (I’ve been on holiday, so I didn’t use the system).
At the moment I haven’t restarted or did anything, so maybe I could get some tips about how to troubleshoot this further.
Edit: I just found out that the log-file was bigger than shown in the terminal. I’ve copied the last rows where there are warnings. Those warnings seem to have something to do with the Mi-connection. I see some disconnect, after that some connect. I don’t really know what to make of it…
2022-09-29 06:27:16.837 [INFO ] [miio.internal.cloud.MiCloudConnector] - Repeated errors logging on to Xiaomi cloud. Cleaning stored cookies
2022-09-29 06:27:17.040 [INFO ] [miio.internal.cloud.MiCloudConnector] - Cannot execute request. service token or userId missing
2022-09-29 14:08:32.687 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 66ed6414-bf69-43a3-affd-6b522d6b5b62, base URL = http://localhost:8080)
2022-09-29 14:12:15.343 [WARN ] [e.californium.scandium.DTLSConnector] - Shutdown DTLS connector on [0.0.0.0/0.0.0.0:33568] executor not terminated in time!
2022-09-29 14:15:22.143 [WARN ] [e.californium.scandium.DTLSConnector] - Shutdown DTLS connector on [0.0.0.0/0.0.0.0:39092] executor not terminated in time!
2022-09-29 14:16:24.767 [WARN ] [e.californium.scandium.DTLSConnector] - Shutdown DTLS connector on [0.0.0.0/0.0.0.0:58431] executor not terminated in time!
2022-09-29 14:20:02.607 [WARN ] [e.californium.scandium.DTLSConnector] - Shutdown DTLS connector on [0.0.0.0/0.0.0.0:43784] executor not terminated in time!
2022-09-29 14:21:36.271 [WARN ] [e.californium.scandium.DTLSConnector] - Shutdown DTLS connector on [0.0.0.0/0.0.0.0:47484] executor not terminated in time!
2022-09-29 14:23:40.982 [WARN ] [e.californium.scandium.DTLSConnector] - Shutdown DTLS connector on [0.0.0.0/0.0.0.0:53299] executor not terminated in time!
2022-09-29 14:29:14.599 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 66ed6414-bf69-43a3-affd-6b522d6b5b62, base URL = http://localhost:8080)
2022-09-29 14:29:44.525 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 66ed6414-bf69-43a3-affd-6b522d6b5b62, base URL = http://localhost:8080)
2022-09-29 14:29:48.998 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 66ed6414-bf69-43a3-affd-6b522d6b5b62, base URL = http://localhost:8080)
2022-10-03 15:07:16.470 [INFO ] [miio.internal.cloud.MiCloudConnector] - Repeated errors logging on to Xiaomi cloud. Cleaning stored cookies
2022-10-03 15:07:16.648 [INFO ] [miio.internal.cloud.MiCloudConnector] - Cannot execute request. service token or userId missing
2022-10-03 23:15:36.414 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: gWindowLights
2022-10-03 23:15:57.870 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: gWindowLights
2022-10-03 23:15:59.543 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: gWindowLights
2022-10-03 23:16:04.030 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: gWindowLights
2022-10-03 23:16:05.884 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: gWindowLights
2022-10-03 23:19:27.044 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: gWindowLights
2022-10-03 23:19:30.475 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: gWindowLights
2022-10-03 23:55:47.971 [WARN ] [ab.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.io.monitor.internal.EventLogger@19e82dc' takes more than 5000ms.
2022-10-04 02:14:03.302 [WARN ] [org.eclipse.jetty.server.HttpChannel] - google.com:443
java.lang.StringIndexOutOfBoundsException: begin 0, end -1, length 14
at java.lang.String.checkBoundsBeginEnd(String.java:3319) ~[?:?]
at java.lang.String.substring(String.java:1874) ~[?:?]
at org.ops4j.pax.web.service.spi.model.ServerModel.matchPathToContext(ServerModel.java:370) ~[?:?]
at org.ops4j.pax.web.service.spi.model.ServerModel.matchPathToContext(ServerModel.java:310) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:73) ~[?:?]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.Server.handle(Server.java:516) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.46.v20220331]
