Hi to all.
Since Saturday i have this problem without doing something at the system:
2020-03-23 06:31:34.091 [ERROR] [io.openhabcloud.internal.CloudClient] - Error connecting to the openHAB Cloud instance: {}
at io.socket.engineio.client.Transport.onError(Transport.java:63) [bundleFile:?]
at io.socket.engineio.client.transports.WebSocket.access$400(WebSocket.java:24) [bundleFile:?]
at io.socket.engineio.client.transports.WebSocket$1$5.run(WebSocket.java:107) [bundleFile:?]
at io.socket.thread.EventThread$2.run(EventThread.java:80) [bundleFile:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_232]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_232]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_232]
at java.net.SocketInputStream.read(SocketInputStream.java:210) ~[?:1.8.0_232]
at java.net.SocketInputStream.read(SocketInputStream.java:141) ~[?:1.8.0_232]
at sun.security.ssl.InputRecord.readFully(InputRecord.java:465) ~[?:1.8.0_232]
at sun.security.ssl.InputRecord.read(InputRecord.java:503) ~[?:1.8.0_232]
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:975) ~[?:1.8.0_232]
at sun.security.ssl.SSLSocketImpl.readDataRecord(SSLSocketImpl.java:933) ~[?:1.8.0_232]
at sun.security.ssl.AppInputStream.read(AppInputStream.java:105) ~[?:1.8.0_232]
at okio.Okio$2.read(Okio.java:139) ~[?:?]
at okio.AsyncTimeout$2.read(AsyncTimeout.java:237) ~[?:?]
at okio.RealBufferedSource.request(RealBufferedSource.java:67) ~[?:?]
at okio.RealBufferedSource.require(RealBufferedSource.java:60) ~[?:?]
at okio.RealBufferedSource.readByte(RealBufferedSource.java:73) ~[?:?]
at okhttp3.internal.ws.WebSocketReader.readHeader(WebSocketReader.java:113) ~[?:?]
at okhttp3.internal.ws.WebSocketReader.processNextFrame(WebSocketReader.java:97) ~[?:?]
at okhttp3.internal.ws.RealWebSocket.loopReader(RealWebSocket.java:262) ~[?:?]
at okhttp3.internal.ws.RealWebSocket$2.onResponse(RealWebSocket.java:201) ~[?:?]
at okhttp3.RealCall$AsyncCall.execute(RealCall.java:141) ~[?:?]
at okhttp3.internal.NamedRunnable.run(NamedRunnable.java:32) ~[?:?]
... 3 more
2020-03-23 06:32:54.754 [ERROR] [io.openhabcloud.internal.CloudClient] - Error connecting to the openHAB Cloud instance: {}
io.socket.engineio.client.EngineIOException: xhr post error
at io.socket.engineio.client.transports.PollingXHR.access$000(PollingXHR.java:26) [bundleFile:?]
at io.socket.engineio.client.transports.PollingXHR$4$1.run(PollingXHR.java:104) [bundleFile:?]
Caused by: java.io.IOException: 502
at io.socket.engineio.client.transports.PollingXHR$Request$1.onResponse(PollingXHR.java:234) ~[?:?]
... 3 more
Has someone the same problem?
Thanks and greetings,
Markus
The error arrives every 10-30 seconds.
I have cleaned the cache with two restars, nothing changed.
Then i used a backup of january, which runs before perfect. Same problem.
So i think, the myopenhab service himself or another binding (http request) has a problem.
Some bindings goes offline from time to time. All with http request.
Tado, nanoleaf, openweathermap, tankerkönig, home connect goes offline from time to time.
Greetings,
Markus
How can i use this? 2020-03-25 16:40:48.475 [WARN ] [okhttp3.OkHttpClient ] - A connection to https://myopenhab.org/ was leaked. Did you forget to close a response body? To see where this was allocated, set the OkHttpClient logger level to FINE: Logger.getLogger(OkHttpClient.class.getName()).setLevel(Level.FINE);
Markus
This warning has been mentioned several times in the forum and it’s nothing to worry about unless it’s repeating over and over.
EDIT: I just read where you mentioned it occurs ever 10-30 seconds.
You can uninstall Opencloud via PaperUI, stop OH and delete the UUID found in /var/lib/openhab2/UUID. Restart OH, reinstall Opencloud and a new UUID will be created. Get the new ID and log into the opencloud site to enter the new UUID.
Hi H102.
Thanks for your help.
Have all done you said. When i reinstall the cloud service, the connection error arrives directly.
Can i do something else.
Greetings, Markus
Since changing the UUID I would stop OH and clean the cache again. After OH has fully restarted (watch the logs) then restart OH with sudo systemctl restart openhab2 and wait for it to fully start then run a second restart.
2020-03-25 19:27:06.125 [ERROR] [io.openhabcloud.internal.CloudClient] - Error connecting to the openHAB Cloud instance: {}
io.socket.engineio.client.EngineIOException: xhr poll error
at io.socket.engineio.client.transports.PollingXHR.access$100(PollingXHR.java:26) [bundleFile:?]
at io.socket.engineio.client.transports.PollingXHR$6$1.run(PollingXHR.java:140) [bundleFile:?]
Caused by: java.io.IOException: 400
... 3 more
2020-03-25 19:27:32.322 [ERROR] [io.openhabcloud.internal.CloudClient] - Error connecting to the openHAB Cloud instance: {}
io.socket.engineio.client.EngineIOException: websocket error
Caused by: java.net.SocketException: Connection reset
... 3 more
After some testings, i have used a new system, pi3, and installed a new openhabcloud account here too.
And there is the same problem.
So it couldn’t be a binding and my system is okay.
Any ideas?
Greetings,
Markus
Yes, this ist correct.
Its a fritz Box avm, i doen’t have changed anything there.
I will take a look for it there.
Is there something that changed from the opebhabcloud side?
Greetings,
Markus
