i was manged to open it (read only) and it is set to false …
i am running grafana in a docker container so there will be more effort to get this running.
once i come up with a solution i’ll post it here as well.
Thanks for pointing that out!
I had to configure global variables to be considered while building the docker image since configuration in the ini is not possible after building. here’s my working config:
