Hi people i need help, i want move Webview item inside Group, google has’t provided answer for my question ))) Can some one help me please ?
my home.items
Group GSM “Mobile network”
String gsmSMSrec “Received sms message [%s]” (GSM)
my home.sitemap
Group item=GSM
Webview url=“http://0.0.0.0/dot.php”
Is it possible to declared Webview into items ?
Thanks in advance
No, this isn’t possible. Please forget about groups when designing an UI, this is crap. You can’t control the order of group members (well, in fact you can by listing all items in one file, but this way only one order per group), you can’t setup special appearance as color changing label, hiding items dependent on an item state, special label and so on.
The only solution is to write down the entire sitemap, so instead of
Group item=myGroup
just write
Text label="Mobile network" {
Text item=gsmSMSrec
Webview url=“http://0.0.0.0/dot.php” //pretty sure the ip is wrong ;)
In fact, you even could use
Group item=GSM {
but be aware that you loose control over your item(s).
Thanks a lot for answer, yes IP is wrong just sample
By the way, can you please help me with installation of IpCamera add-on, i could find this add-on in the Paper UI > Add-ons section, is it possible to install it manually ?
No, sorry, you will need a compiled jar for (manual) installation. As I don’t use this binding, I have no idea.
Ok thanks,
Last questio do you know who to create rule to monitor state ip thought Network binding ?
For instance i have following rule:
rule “Test mqtt”
Item errorMSG received update
if (errorMSG.state==“HELLO”)
sendPushbulletNote("mymail@mail.com",“IT WORKED”, “Mode is ON”)
How to make same thing to detect network ip down or up with Network Binding add-on , thanks in advance
Just install the network binding and create an item:
thing:
Thing network:pingdevice:mydevice "My Device" @ "Ping" [ hostname="ip.or.hostname", port=0, retry=1, timeout=5000, refresh_interval=60000, use_system_ping="false", dhcplisten="false" ]
item:
Switch myPingDevice "My Device" { channel="network:pingdevice:mydevice:online" }
rule:
rule myPingRule
Item myPingDevice changed
logInfo("ping","myPingDevice changed state to {}",myPingDevice.state)
That awesome and easy thank a lot for help
i will test it right now
Another least question
Is possible same way as
myPingDevice.state
pass MQTT message ?:
rule “Test mqtt”
sendPushbulletNote("mymail@mail.com",“IT WORKED”, “to here ?”)
Thanks a again
I don’t know exactly what’s the goal.
item:
String MyMQTTitem "MQTT item" { mqtt="< [mybroker:topic/to/message:state:default]" }
rule:
rule myMQTTmessage
Item MyMQTTitem changed
val string sMessage = "The Message was '" + MyMQTTitem.state.toString + "'"
sendPushbulletNote("mymail@mail.com",“IT WORKED”, sMessage)
That great, thanks a lot for help, i don’t want bother you again, could you please provide reference or some documentation for that configuration ?
One more before i stop asking ))) Can i parse MQTT message and add between message some String value, for instance :
thought MQTT i receiving time online main controller like that - 2:23:22 can i change it to 2 Day : 22 Hours : 22 Minute or better to do it from controller side?
And is it wait to get system time and date from server , to show current date and time ?
Works great, only what i changed is :
Item securMSG received update
Thanks a lot, you help me a lot.
should be easy…
val string sDay = myItem.state.toString.split(':').get(0)
val string sHour = myItem.state.toString.split(':').get(1)
val string sMinute = myItem.state.toString.split(':').get(2)
val string sMessage = sDay + " Day" + if(sDay!="1") "s" + " : " + sHour + " Hour" + if(sHour!="1") "s" + " : " + sMinute + " Minute" + if(sMinute!="1") "s"
If there is a leading 0 for hours and minutes, you will have to add a 0 to the if-statement:
val string sMessage = sDay + " Day" + if(sDay!="1") "s" + " : " + sHour + " Hour" + if(sHour!="01") "s" + " : " + sMinute + " Minute" + if(sMinute!="01") "s"
For current Time and Date, you should use the ntp binding.
In question of code reference, there is a lot of stuff (code examples) in the community, but no reference, as no one has written a reference yet. You can get some information under Rules | openHAB though, and there are some links in the document for further information.
Where i should declare this code, in rules ? or it possible direct in item ?
my home.item:
String timeOnline "Time Online [%s]" <time> {mqtt="<[broker:/monitor/main/timeOnline:state:default]"}
my home.sitemap:
Frame label="Main Controller Status" {
Text item=timeOnline
When it comes to vars and vals, we’re always talking about rules…
If you want the same thing in the label, you will have to use a Java Script:
String timeOnline "Time Online [%s]" <time> {mqtt="<[broker:/monitor/main/timeOnline:state:JS(timetotext.js)]"}
and in ./transformations/timetotext.js:
(function(dataString) {
val sArray = dataString.split(':');
val reply = sArray[0] + " Day" + if(sArray[0] != "1") "s" + " : " + sArray[1] + " Hour" + if(sArray[1] != "01") "s" + " : " + sArray[2] + " Minute" + if(sArray[2] != "01") "s";
return reply;
})(input)
I did not test this script!
Thanks, a don’t want play with JavaScript easy changed it on the controller side
I found some tricks who to forward all log to syslog server but couldn’t understand where this code should be located:
How to redirect your log entries to the syslog
You just need to add some lines to your logback.xml.
Like:
<appender name="SYSLOG" class="ch.qos.logback.classic.net.SyslogAppender"> <syslogHost>localhost</syslogHost> <facility>AUTH</facility> <suffixPattern>{}openhab: [%thread] %logger %msg</suffixPattern> </appender> <root level="INFO"> <appender-ref ref="SYSLOG" /> </root>
Link:
can you please help me with that ?
This is outdated, as we’re on OH2! The logging is completely different to OH1. There are several postings in the community, just do a little search
