Weird behaviour on a virtual switch
I have a virtual switch to controll my Xioami vacuum via Alexa
.Items:
String actionControl  "Steuern"   <vacuum>  (gVac)    {channel="miio:vacuum:0705301C:actions#control" }
.rules:
val String filename = "Roborock.rules"
rule "Roborock alexa"
Item VacAlexa received command
switch VacAlexa.state.toString{
case "ON":{
actionControl.sendCommand("vacuum")
logInfo(filename,"Staubsauger wurde eingeschalten")
case "OFF":{
actionControl.sendCommand("dock")
logInfo(filename,"Staubsauger wurde ausgeschalten")
logs:
2019-01-07 15:53:08.204 [ome.event.ItemCommandEvent] - Item 'VacAlexa' received command ON
2019-01-07 15:53:08.233 [nt.ItemStatePredictedEvent] - VacAlexa predicted to become NULL
rules not getting fired, where does the ā€˜Prediction’ in the logs come from?
@kai wrote about this a while back – can’t lay hands on the reference at the moment. Essentially, the result of a new ā€œfeatureā€ in core OH. Causes grief specifically to me also specifically because rules don’t fire. The hack around it is to use the phrase
... , autoupdate="false" ....}
in the channel descriptor for the real item. Adding that to the real item seems to make derived-virtual-item targetted rules fire as expected.
Tidy up a bit:
    switch receivedCommand {
        case ON:{
        case OFF:{
