Hi all, I am setting up openHAB 3.4.2 on a RPi 4. But I experience some weirdness when using .map files in /etc/openhab/transform.
As I did for my Javascript transformations, I created a separate folder ‘mappings’ for mapping-files. But no matter how I defined the path (MAP:/mappings/test.map or MAP:mappings/test.map or MAP:/mappings/test.map etc.) it failed reading it:
Blockquote [WARN ] [t.generic.ChannelStateTransformation] - Executing the MAP-transformation failed: Could not find configuration ‘/mappings/test.map’ or failed to parse it.
(changing permissions/owner made no difference)
Then I moved the file one folder back to the ‘transform’ folder and use MAP:test.map, but still no success.
Created a new file test5.map and set MAP:test5.map does work allright.
But a new file with the name ‘LedEffectLabeltoESP.map’ fails…
So my questions are:
- Is it true that subfolders for map-transformation files are not allowed?
- Or how should it be set then?
- Are there restrictions for filenames in this particular setting?
Ciao!
