Hello everyone! Today i’ve successfully deployed my newly written Herzborg binding. Herzborg seems to have lots of automation hardware, but here only curtain motors gained popularity, so the binding supports only them. Still, if anyone is interested, enjoy.
I’ll put together a binary release if there’s an interest
Note for maintainers: a pull request against V3 addons repository is here: https://github.com/openhab/openhab-addons/pull/9327
Hello! Is there anyone here? The pull request is still hanging there, no response since november.
You need to be more patient. We just have a couple of maintainers, reviewing PRs in their spare time…
Well, OK, just it’s been about 3 months…
Come on, this is not completely true. Last changes you made have been sbmitted on February 2nd.
You also should check your PR, as the Jenkins build failed.
So please first make Jenkins happy again and then let’s see when a maintainer finds time for your PR, which is not the oldest btw…
Well, build logs have been lost too. So i’ve rebased it, checked locally (it builds OK) and re-pushed. Let’s see.
Yes, i made changes according to @hilbrand 's requests and never heard back.
Build failed with code styling issues…
[ERROR] Failed to execute goal com.diffplug.spotless:spotless-maven-plugin:2.0.3:check (codestyle_check) on project org.openhab.binding.herzborg: The following files had format violations:
[ERROR] src/main/resources/OH-INF/thing/thing-types.xml
[ERROR] @@ -37,7 +37,7 @@
[ERROR] \t\t\t\t<description>Device·address·on·the·bus.</description>
[ERROR] \t\t\t\t<default>65278</default>
[ERROR] \t\t\t</parameter>
[ERROR] -\t\t\t<parameter·name="poll_interval"·type="integer"·unit·="s">
[ERROR] +\t\t\t<parameter·name="poll_interval"·type="integer"·unit="s">
[ERROR] \t\t\t\t<label>Poll·Interval</label>
[ERROR] \t\t\t\t<description>Poll·interval·in·seconds</description>
[ERROR] \t\t\t\t<default>1</default>
[ERROR] Run 'mvn spotless:apply' to fix these violations.
[ERROR] -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] After correcting the problems, you can resume the build with the command
[ERROR] mvn <goals> -rf :org.openhab.binding.herzborg
Yes, thank you, i have examined it myself and fixed it up yesterday.
