I am trying to implement a rule that would switch on the outside lights when I get near home.
The rule currently consist of:
rule "Welcome Home Lights"
Item iPhone_DistanceFromHome changed
if(iPhone_DistanceFromHome.state <= 800)
if((hour >= 20) || (hour <= 5))
if(Light_Outside_ESPurna_10.state == OFF){
sendCommand(Light_Outside_ESPurna_10, ON)
Problem with above is that the lights would now to turn on every time that iPhone_DistanceFromHome changes and I am near/at home. How would I get this rule to only fire once when I enter the 800m radius and then re-activate when I leave the 800m radius again to be triggered the next time I arrive home?
@luckymallari, Thanks so much for the guidance. I have now learned the use and appreciate proxy items.
I have ended up creating a proxy item for each family member to indicate whether they are at home or not and also to indicate whether the sun is up or not:
Items File:
Switch JWIsHome "JW Is Home [%s]"
Switch SunIsUp "The Sun Is Up [%s]"
Rules File:
rule "JW Is Home"
Item iPhone_DistanceFromHomeJW changed
if(iPhone_DistanceFromHomeJW.state <= 900)
postUpdate(JWIsHome, ON)
rule "JW Is Away"
if(iPhone_DistanceFromHomeJW.state >= 901)
postUpdate(JWIsHome, OFF)
rule "Sunrise Event Occured"
Channel 'astro:sun:home:rise#event' triggered START
sendTelegram("bot1", "Sunrise Event Occured")
postUpdate(SunIsUp, ON)
rule "Sunset Event Occured"
Channel 'astro:sun:home:set#event' triggered START
sendTelegram("bot1", "Sunset Event Occured")
postUpdate(SunIsUp, OFF)
rule "Welcome Home Lights For JW"
Item JWIsHome changed to ON
if(SunIsUp.state==OFF){
sendCommand(CarPortLigtsTimer, ON)
rule "Welcome Home Lights Timer"
Item CarPortLigtsTimer changed to ON
if(timer == null || timer.hasTerminated) {
Switch_ESPurna_28.sendCommand(ON)
timer = createTimer(now.plusMinutes(10), [ |
Switch_ESPurna_28.sendCommand(OFF)
timer = null
else {
timer.reschedule(now.plusMinutes(10))
With this I can probably make use of these proxy items for other tasks in future as well…
I dont’t know which unit “DistanceFromHome” is, but I would use a hysteresis. If the values are varying a little bit and you are at Distance 900 and the values toggle between 900 and 901, then you have a toggling IsHome state.
I would suggest a hysteresis which is about double the value variation on any the distance of interest. For this just stay at the distance and record the values for DistanceFromHome. If the value is varying with 10 Units (e.g. from 895…905) I would suggest a hysteresis of 20 Units:
DistanceFromHome < 900: IsHome=ON
DistanceFromHome > 920: IsHome=OFF
In your case you’re just getting a lot of updates of the items, but your rule is only triggering once (changed to ON). If you want to turn the lights off when you are leaving, then you are running in troubles…
