I’m pretty confused whether wemo-binding supports the LED bulbs. I have managed to send commands using the exec-binding and a nodejs script that found but it inserts a delay which is pretty annoying. Can someone give some guidance whether there is a “native” way to manage wemo bulbs (or Osram Lightify) directly using only the wemo-link ?
You are not imposing at all.
After struggling with the devices for quite a long time, I was able to find a way to solve the problems and created a pull request for eclipse smart home.
So the Bridge and LED support should be available soon for opnHAB 2.0. Just have to finish a little issue with reliability of discovery.
I also got hold of a WeMo maker, and this will be supported with the same release.
Now I have to find a way how to adopt this for openHAB 1.x, which is a bit harder. But I will do my best to have this done as well. Don’t think it will make it into 1.8 release, cause of the release timeline.
But when I have it running, i will post the binding her.
The discovery in WeMo 1.x Binding reports a WeMo link, but there are no methods implemented to control it.
Support will be available with openHAB 2.0 after my PR for Eclipse SmartHome is merged.
Last week I decided not to downport this into the 1.x Binding.
Therefore I can now announce that support for the WeMo Maker in will be available in openHAB 2.0 as well.
@hmerk Is there any chance your updated binding for 1.8 can bring the power update down from 60 seconds to maybe 5 seconds for the wemo insight connected via WiFi?
I found this script witch is supposed to be able to control all wemo devices including the Wemo bulbs.
I can use the LINK LIST command to see all connected devices and GETSTATE to se the status of the device. But I can’t turn change the state of any of the bulbs. Does anyone know how to modify the script to fix this?
My latest additions got merged into eclipse smarthome, so the next version of openHAB2 will support the WeMo LED bulbs connected to the WeMo link bridge.
The are some more additions to be announced with that version :
Support for WeMo Maker (relay and sensor)
Use of GENA subscriptions to receive device updates (so the motion sensor should notify imediately about changes)
Additional channels for WeMo Insight devices, as introduced with latest openHAB 1.x version of the binding.
Does that mean the Beta 2 version that just came out?
I would really like to continue using the link, and the led bulbs, but it has been frustrating at best watching people design scripts that are Xnix only, or months going by saying that it should be working in a couple of weeks…
Yes, the latest openHAB2 Beta Snapshot does include the new WeMo Binding version withe the features mentrioned in my last post.
I just checked it and after starting openHab2, all my WeMos were put into inbox
Thank you for your hard work.
I do not see the wemo binding in openhab2-addons github project. Could you please share the location of the wemo binding source code?
Hey, so I tried openhab2 this weekend, seems to work fine so far…
However, my wemo led lights are stuck “initializing” in openhab2. All my other devices that are autosensed (hue bridge/lights, wemo Motion, wemo switch) work fine. Not sure what logs (if any) you’d need to help me solve this though.
First of all, make shure your WeMo link and the LED lights are running the latest firmware version. Please post the version if yours.
I am not quite sure about debug config in oh2, but I will investigate on this and post a guide for debugging WeMo Binding in oh2 later.
