I’ve updated to version 3.1 of OpenHab and while everything work properly, there’s one thing that is bugging me.
I have a thing for a wemo dimmer with a dimmer item and a switch item connected to the channel. The switch item work properly, turning on/off with latest value. The dimmer also work, but always reset to 100 whatever the real value is. If I slide to 45, the light does dim to 45 but the slider stop at 45 then update to 100 everytime.
I’ve tried using a floorplan with a widget and the samething happen.
2021-09-25 12:02:07.511 [TRACE] [o.internal.handler.WemoDimmerHandler] - Command 'ON' received for channel 'wemo:dimmer:Dimmer-1_0-241742K1502433:brightness'
2021-09-25 12:02:08.502 [DEBUG] [o.internal.handler.WemoDimmerHandler] - Received pair 'BinaryState':'1' (service 'basicevent1') for thing 'wemo:dimmer:Dimmer-1_0-241742K1502433'
2021-09-25 12:02:08.503 [DEBUG] [o.internal.handler.WemoDimmerHandler] - State 'ON' for device 'wemo:dimmer:Dimmer-1_0-241742K1502433' received
2021-09-25 12:02:12.251 [TRACE] [o.internal.handler.WemoDimmerHandler] - Command '40.0' received for channel 'wemo:dimmer:Dimmer-1_0-241742K1502433:brightness'
2021-09-25 12:02:12.387 [DEBUG] [o.internal.handler.WemoDimmerHandler] - Received pair 'BinaryState':'1' (service 'basicevent1') for thing 'wemo:dimmer:Dimmer-1_0-241742K1502433'
2021-09-25 12:02:12.388 [DEBUG] [o.internal.handler.WemoDimmerHandler] - State 'ON' for device 'wemo:dimmer:Dimmer-1_0-241742K1502433' received
Seems they have changed the firmware sometime after i developed this. At that time, the actual brightness was reported too.
I will add another check to only update values if there is a real change.
Unfortunately, this will take some time.
ah ok, I’ll wait for the release then. Does the new version give fix for
wemo.internal.handler.WemoHandler] - Failed to get actual state for device ‘wemo:lightswitch:Lightswitch-1_0-221813K13000C6’: null
I’m getting this error more and more. I restart openhab and it start working again, but it work for maybe 1 to 3 hours and I lose control 1 by 1 of each wemo device.
Please note that you need to delete your Wemo Things and have them rediscovered, as I introduced new properties to be used for polling.
This will be no issue, as the Thing will get the same ID as before…
oh yeah, just saw my docker is on 3.2.0 and it seems to be fixed. I’ll check back later because I was sure that last week I had the problem. I’ll try the 3.3 snapshot
