Hi Hans,
Thank You for the response. One question, do I need backup the existing weemo binding or remove it? If so where is it located?
Just uninstall the Binding via PaperUI and put the jar into addons folder.
If you installed it with an entry in addons.cfg, remove it from there.
Thank You Hans, for all your help, I’m able to see the Dimmer switch now!
Hi Hans still does not work.
I have set your binding at /Applications/openhab/addons
I removed wemo from /Applications/openhab/conf/services/addons.cfg
I have my sonos installed.
I have also installed Eclipse IoT Market mentioned here.
Yet I still get the old version 2.4 downloaded from somwhere instead of yours when I try to bind it using paperUI. No new devices appear on search neither new types.
There is a missing step.
Fernando
Please stop openHAB, clear the cache and restart.
Finally finished adding Dimmer support to the Binding and created a pull request for it.
