I’m using 4 WEMO Insight Switches.
I have configure the things and the items in files.
If I start openHAB2 the things were added, initialized and then the state switches to online.
Then I start the classicUI:
The state of the items shows OFF (that is wrong), and the currentPower is not set.
Then I rename the file _default.things to _default.things.xxx.
After a few seconds I rename the file back to _default.things.
Now the state of the items shows ON (that is correct), and the currentPower is set to the correct value.
What is wrong?
Greetings
Horst
events.log (first start)
2016-10-29 18:45:17.951 [ItemChannelLinkAddedEvent ] - Link ‘waschmaschineOgEnergyTotal-wemo:insight:Insight2:energyTotal’ has been added.
2016-10-29 18:45:17.966 [ItemChannelLinkAddedEvent ] - Link ‘trocknerEg-wemo:insight:Insight3:state’ has been added.
2016-10-29 18:45:17.966 [ItemChannelLinkAddedEvent ] - Link ‘trocknerOgCurrentPower-wemo:insight:Insight4:currentPower’ has been added.
2016-10-29 18:45:17.966 [ItemChannelLinkAddedEvent ] - Link ‘waschmaschineEgEnergyTotal-wemo:insight:Insight1:energyTotal’ has been added.
2016-10-29 18:45:17.966 [ItemChannelLinkAddedEvent ] - Link ‘trocknerEgCurrentPower-wemo:insight:Insight3:currentPower’ has been added.
2016-10-29 18:45:17.966 [ItemChannelLinkAddedEvent ] - Link ‘waschmaschineOg-wemo:insight:Insight2:state’ has been added.
2016-10-29 18:45:17.966 [ItemChannelLinkAddedEvent ] - Link ‘trocknerEgEnergyTotal-wemo:insight:Insight3:energyTotal’ has been added.
2016-10-29 18:45:17.966 [ItemChannelLinkAddedEvent ] - Link ‘waschmaschineEg-wemo:insight:Insight1:state’ has been added.
2016-10-29 18:45:17.966 [ItemChannelLinkAddedEvent ] - Link ‘trocknerOg-wemo:insight:Insight4:state’ has been added.
2016-10-29 18:45:17.966 [ItemChannelLinkAddedEvent ] - Link ‘trocknerOgEnergyTotal-wemo:insight:Insight4:energyTotal’ has been added.
2016-10-29 18:45:17.966 [ItemChannelLinkAddedEvent ] - Link ‘waschmaschineEgCurrentPower-wemo:insight:Insight1:currentPower’ has been added.
2016-10-29 18:45:17.966 [ItemChannelLinkAddedEvent ] - Link ‘waschmaschineOgCurrentPower-wemo:insight:Insight2:currentPower’ has been added.
2016-10-29 18:45:20.371 [ThingAddedEvent ] - Thing ‘wemo:insight:Insight1’ has been added.
2016-10-29 18:45:20.371 [ThingAddedEvent ] - Thing ‘wemo:insight:Insight2’ has been added.
2016-10-29 18:45:20.371 [ThingAddedEvent ] - Thing ‘wemo:insight:Insight3’ has been added.
2016-10-29 18:45:20.371 [ThingAddedEvent ] - Thing ‘wemo:insight:Insight4’ has been added.
2016-10-29 18:45:20.424 [hingStatusInfoChangedEvent] - ‘wemo:insight:Insight1’ changed from UNINITIALIZED to INITIALIZING
2016-10-29 18:45:20.424 [hingStatusInfoChangedEvent] - ‘wemo:insight:Insight2’ changed from UNINITIALIZED to INITIALIZING
2016-10-29 18:45:20.440 [hingStatusInfoChangedEvent] - ‘wemo:insight:Insight1’ changed from INITIALIZING to ONLINE
2016-10-29 18:45:20.440 [hingStatusInfoChangedEvent] - ‘wemo:insight:Insight3’ changed from UNINITIALIZED to INITIALIZING
2016-10-29 18:45:20.440 [hingStatusInfoChangedEvent] - ‘wemo:insight:Insight2’ changed from INITIALIZING to ONLINE
2016-10-29 18:45:20.440 [hingStatusInfoChangedEvent] - ‘wemo:insight:Insight4’ changed from UNINITIALIZED to INITIALIZING
2016-10-29 18:45:20.440 [hingStatusInfoChangedEvent] - ‘wemo:insight:Insight4’ changed from INITIALIZING to ONLINE
2016-10-29 18:45:20.440 [hingStatusInfoChangedEvent] - ‘wemo:insight:Insight3’ changed from INITIALIZING to ONLINE
2016-10-29 18:45:21.357 [ThingUpdatedEvent ] - Thing ‘wemo:insight:Insight1’ has been updated.
2016-10-29 18:45:21.357 [ThingUpdatedEvent ] - Thing ‘wemo:insight:Insight2’ has been updated.
2016-10-29 18:45:21.357 [ThingUpdatedEvent ] - Thing ‘wemo:insight:Insight3’ has been updated.
2016-10-29 18:45:21.357 [ThingUpdatedEvent ] - Thing ‘wemo:insight:Insight4’ has been updated.
_default.things:
wemo:insight:Insight1 [ udn=“Insight-1_0-221450K1200xx1”]
wemo:insight:Insight2 [ udn=“Insight-1_0-221503K1200xx2”]
wemo:insight:Insight3 [ udn=“Insight-1_0-221514K1200xx3”]
wemo:insight:Insight4 [ udn=“Insight-1_0-221540K1200xx4”]
_default.items:
Group gUG “Untergeschoss” [ “home-group” ]
Group UG_Waschkueche “Waschküche” (gUG)
Switch waschmaschineEg “EG Waschmaschine” (UG_Waschkueche) {channel=“wemo:insight:Insight1:state”}
Number waschmaschineEgCurrentPower “EG Stromverbrauch [%.00f]” (UG_Waschkueche) {channel=“wemo:insight:Insight1:currentPower”}
Number waschmaschineEgEnergyTotal “EG WSumme [%.00f]” (UG_Waschkueche) {channel=“wemo:insight:Insight1:energyTotal”}
Switch waschmaschineOg “OG Waschmaschine” (UG_Waschkueche) {channel=“wemo:insight:Insight2:state”}
Number waschmaschineOgCurrentPower “OG Stromverbrauch [%.00f]” (UG_Waschkueche) {channel=“wemo:insight:Insight2:currentPower”}
Number waschmaschineOgEnergyTotal “OG WSumme [%.00f]” (UG_Waschkueche) {channel=“wemo:insight:Insight2:energyTotal”}
Switch trocknerEg “EG Trockner” (UG_Waschkueche) {channel=“wemo:insight:Insight3:state”}
Number trocknerEgCurrentPower “EG Stromverbrauch [%.00f]” (UG_Waschkueche) {channel=“wemo:insight:Insight3:currentPower”}
Number trocknerEgEnergyTotal “EG TSumme [%.00f]” (UG_Waschkueche) {channel=“wemo:insight:Insight3:energyTotal”}
Switch trocknerOg “OG Trockner” (UG_Waschkueche) {channel=“wemo:insight:Insight4:state”}
Number trocknerOgCurrentPower “OG Stromverbrauch [%.00f]” (UG_Waschkueche) {channel=“wemo:insight:Insight4:currentPower”}
Number trocknerOgEnergyTotal “OG TSumme [%.00f]” (UG_Waschkueche) {channel=“wemo:insight:Insight4:energyTotal”}
