I wanted to share the rule I used to alert the house using Amazon TTS with the WeMo Insight Plug on a US Clothes Washer.
Hope this helps someone else.
Items:
String ClothesWasher_Proxy "Clothes Washer is [MAP(clotheswasher_proxy.map):%s]" (WeMo)
Switch InSight_ClothesWasher_State "Washer Outlet Power [MAP(On_Off.map):%s]" <poweroutlet_us> (WeMo) { channel="wemo:insight:Insight-1_0-XXXXXXX:state" }
DateTime InSight_ClothesWasher_LastChangedAt "Last Changed At [%1$tm.%1$td.%1$tY %1$tH:%1$tM]" <time> { channel="wemo:insight:Insight-1_0-XXXXXXX:lastChangedAt" }
Number InSight_ClothesWasher_LastOnFor "Last On For [JS(duration_from_seconds.js):%s]" <time> { channel="wemo:insight:Insight-1_0-XXXXXXX:lastOnFor" }
Number InSight_ClothesWasher_OnToday "On Today [JS(duration_from_seconds.js):%s]" <time> { channel="wemo:insight:Insight-1_0-XXXXXXX:onToday" }
Number InSight_ClothesWasher_OnTotal "On Total [JS(duration_from_seconds.js):%s]" <time> { channel="wemo:insight:Insight-1_0-XXXXXXX:onTotal" }
Number InSight_ClothesWasher_TimeSpan "Time Span [JS(duration_from_seconds.js):%s]" <time> { channel="wemo:insight:Insight-1_0-XXXXXXX:timespan" }
Number InSight_ClothesWasher_AveragePower "Average Power [%.1f W]" <energy> { channel="wemo:insight:Insight-1_0-XXXXXXX:averagePower" }
Number InSight_ClothesWasher_CurrentPower "Current Power [%.1f W]" <energy> { channel="wemo:insight:Insight-1_0-XXXXXXX:currentPower" }
Number InSight_ClothesWasher_EnergyToday "Energy Today [%.1f W]" <energy> { channel="wemo:insight:Insight-1_0-XXXXXXX:energyToday" }
Number InSight_ClothesWasher_EnergyTotal "Energy Total [%.1f W]" <energy> { channel="wemo:insight:Insight-1_0-XXXXXXX:energyTotal" }
Number InSight_ClothesWasher_StandByLimit "Stand By Limit [%s]" <time> { channel="wemo:insight:Insight-1_0-XXXXXXX:standByLimit" }
Mapping:
Done=Done
done=Done
DONE=Done
Empty=Empty
empty=Empty
EMPTY=Empty
Running=Running
running=Running
RUNNING=Running
null=Unknown
NULL=Unknown
Rule:
rule "Clothes Washer Cycle Done"
Item InSight_ClothesWasher_CurrentPower changed
var Washer = InSight_ClothesWasher_CurrentPower.state as Number
// logInfo("Washer", "InSight_ClothesWasher_CurrentPower state is " + InSight_ClothesWasher_CurrentPower.state)
// logInfo("Washer", "Variable Washer value is " + Washer)
// Washer - Current Power when idle is 2.0 W
if (currHour.state !== null) {
currHourVariable = now.getHourOfDay
currHour.postUpdate(currHourVariable) }
if (ClothesWasher_Proxy != 'Done' && ClothesWasher_Proxy != 'Empty' && currHour.state >= 7 && currHour.state <= 22 && Alexa_Status.state == 'ONLINE' && Washer < 3 ) {
ClothesWasher_Proxy.postUpdate('Done')
logInfo("Echo", "-----------------------------------------------------------------------------")
logInfo("Echo", "** Echo Speaking on Living Room")
if (Echo_Living_Room_textToSpeechVolume.state != '40' ) { Echo_Living_Room_textToSpeechVolume.sendCommand('40') }
Thread::sleep(2000) // 2 second wait
Echo_Living_Room_TTS.sendCommand("Excuse me, The clothes washer has completed its wash cycle.")
logInfo("Echo", "Echo speaks - The clothes washer has completed its wash cycle.")
if (Washer > 10 ) {
ClothesWasher_Proxy.postUpdate('Running')
Best, Jay
