Wemo Maker Not Responding
(Negm) #1
Hello All,
For some reason my wemo maker is not working at all.
It was automatically discovered, but the relay/sensor channels are not working.
A log shows only this:
2018-06-12 18:45:40.653 [TRACE] [inding.wemo.handler.WemoMakerHandler] - Command ‘ON’ received for channel ‘wemo:Maker:Maker-1_0-221604S000003A:relay’
2018-06-12 18:45:59.704 [TRACE] [inding.wemo.handler.WemoMakerHandler] - Command ‘OFF’ received for channel ‘wemo:Maker:Maker-1_0-221604S000003A:relay’
Which is basically nothing…
Any help would be appreciated.
Best regards,
Mohamed
(Hans-Jörg Merk) #2
Would you please give us some more information:
OS
Java version
openHAB version
(Negm) #3
Sorry for the not complete information.
OS: Windows 10
Java Version:
openjdk version “10.0.1” 2018-04-17
OpenJDK Runtime Environment Zulu10.2+3 (build 10.0.1+9)
OpenJDK 64-Bit Server VM Zulu10.2+3 (build 10.0.1+9, mixed mode)
OpenHAB version: openHAB 2.4.0 Build #1295
The Wemo Maker is already updated to the latest version
(Hans-Jörg Merk) #4
You are using a wrong Java version, openHAB requieres Java8 !
(Negm) #5
But i thought Java8 is the minimum requirement! so anything higher should work… or not? I just downloaded the latest Zulu Java version
(Hans-Jörg Merk) #6
No, Java8 only.
(Negm) #7
Sorry for the late reply.
I changed today to java8 and it works perfectly.
Many thanks for help :slight_smile:
(Hans-Jörg Merk) #8
Great, thanks for letting us know
