I am using the wemo binding 2.0 with openhanded 2.0 on a raspberry pi.
Today I was playing with some rules and find out, that every time I switched my wemo switch under habpanel or paper UI, the console (karaf) showed me three state changes:
Switched ON:
Item 'Kaffeemaschine_Switch' received command ON
20:08:10.414 [INFO ] [marthome.event.ItemStateChangedEvent] - Kaffeemaschine_Switch changed from OFF to ON
20:08:10.455 [INFO ] [marthome.event.ItemStateChangedEvent] - Kaffeemaschine_Switch changed from ON to OFF
20:08:11.081 [INFO ] [marthome.event.ItemStateChangedEvent] - Kaffeemaschine_Switch changed from OFF to ON
Switched OFF:
Item 'Kaffeemaschine_Switch' received command OFF
20:08:11.899 [INFO ] [marthome.event.ItemStateChangedEvent] - Kaffeemaschine_Switch changed from ON to OFF
20:08:11.986 [INFO ] [marthome.event.ItemStateChangedEvent] - Kaffeemaschine_Switch changed from OFF to ON
20:08:12.059 [INFO ] [marthome.event.ItemStateChangedEvent] - Kaffeemaschine_Switch changed from ON to OFF
Manual activation makes no problems. Working with rules is very complicated with this behaviour.
Has anybody a hint or can help me?
Greetings Johannes
