- Platform information:
- Hardware: CPUArchitecture/RAM/storage
- OS: what OS is used and which version
- Java Runtime Environment: which java platform is used and what version
- openHAB version:
- Issue of the topic: please be detailed explaining your issue
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
Wanted to download and install and it’s gone …Is there a link I can follow to get it back …I found it was much easier to configure than this on screen @#&#($,@#;@
Cant the newer versions of OH still be configured the old way without using a GUI
Don’t want to use GUI …Want to go in and configure via ssh
Maybe admincan put the old links back up
Where were the files installed to ??..?
I thought I was right on that
Hate to disagree, I think that one of the openHAB 2 design principals was that you could always configure things via text, but in real life we are not there yet. Take zwave for example, yes can you configure basic .things but you can’t sent any parameters via text files. Just the other day I was moving to next 2.3 binding and I had to create it via paper first so I could get the access token then I was able to back into text files.
