What is the best method to start executing the rules when all bindings are loaded
I really hate polling rules so instead of @bajan’s suggestion, which I don’t think would work in all cases, I would do the following:
  • Create a Switch Item which will act as a flag indicating that the system is starting
  • In all of your rule that you want to prevent from running until your bindings have finished loading add a check to make sure that Item’s state is OFF
  • Create a system started triggered rule that sets the Item to ON, then sets a timer for however long you need to ensure that all the bindings have loaded that turns the Item back OFF.
Items:
Switch SystemStarting
Rules:
var Timer startedTimer = null
rule "System Started"
    System started
    SystemStarting.sendCommand(ON)
    startedTimer = createTimer(now.plusMinutes(1), [| SystemStarting.sendCommand(OFF)])
rule "Rule that should not run until bindings are loaded"
   Item RuleTriggerItem received upadte
    if(SystemStarting.state == OFF) {
        // rule logic
If you have persistence make sure to exclude SystemStarted from being restored on startup or else there can be a brief time where Nikobus or MIOS events are coming in but the system started rule has not yet executed and if the value is restored on startup it will have an OFF state. By excluding it it will have an Undefined state instead and your checked rules will not execute, preventing this little race condition.
