I’m stuggeling with one of my fibaro roller shutters. All others are detected right. Except of one.
This one is detected as the correct model and is partly working. But no xlm-file was created and some of the properties are wrong. If I delete the node with habmin and let it redetect, again no xml-file is created and it is redetected with wrong settings again.
I compare json db and there is a difference:
Fully working one:
“properties”: {
“zwave_class_basic”: “ROUTING_SLAVE”,
“zwave_class_generic”: “MULTILEVEL_SWITCH”,
“zwave_frequent”: “false”,
“zwave_neighbours”: “”,
“zwave_version”: “25.25”,
“zwave_listening”: “true”,
“zwave_deviceid”: “4096”,
“zwave_nodeid”: “47”,
“zwave_routing”: “true”,
“zwave_beaming”: “true”,
“zwave_class_specific”: “MOTOR_CONTROL_CLASS_B”,
“zwave_manufacturer”: “271”,
“zwave_devicetype”: “770”
partly working one:
“properties”: {
“zwave_listening”: “false”,
“zwave_nodeid”: “46”,
“zwave_routing”: “false”,
“zwave_beaming”: “false”,
Manually editing json-file or/and creating a node xml file does not fix it.
What to do?
