Recently, I was trying to add channels dynamically to my thing. I provided default channel configurations to the XML.
Channel Type Definition XML:
<channel-type id="switch-01">
<item-type>Switch</item-type>
<label>Switch 1</label>
</channel-type>
Thing Type Definition XML:
<thing-type id="smart-switch">
<label>Smart Switch</label>
<description>Smart switch provides advanced functionality than regular switches.</description>
<channels>
<channel id="switch-01" typeId="switch-01" />
</channels>
<config-description-ref uri="gridpal:config:apl-smart-switch" />
</thing-type>
Thing Configuration XML:
<?xml version="1.0" encoding="UTF-8"?>
<config-description:config-descriptions xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:config-description="http://eclipse.org/smarthome/schemas/config-description/v1.0.0"
xsi:schemaLocation="http://eclipse.org/smarthome/schemas/config-description/v1.0.0 http://eclipse.org/smarthome/schemas/config-description-1.0.0.xsd">
<config-description uri="gridpal:config:apl-smart-switch">
<parameter-group name="switch-item-params">
<label>Switch Parameters</label>
</parameter-group>
<parameter name="switch01" type="text" groupName="switch-item-params">
<label>Switch 01</label>
<default>Switchable</default>
<options>
<option value="Switchable">Switchable</option>
<option value="Dimmable">Dimmable</option>
</options>
</parameter>
</config-description>
</config-description:config-descriptions>
The idea is- based on the configuration, the channels item types should vary. For example, if switch-01 is configured to Dimmable during runtime, then channel item type should switch from Switch to Dimmer.
Channels created with different ChannelUID seems to work nicely. However, I want to reuse the existing ChannelUIDs. I tried as I’ve mentioned below. Although in the Paper UI, Dimmer is displayed on the Configuration page, Control page shows Switch UI item. Using REST, I figured out that the item type is actually of Switch. So, it seems the XML is overriding the channel configurations. Kindly let me know the proper way of doing this.
I have tried it the following way-
private void thingStructureChanged()
logger.debug("\n\n[ THING STRUCTURE CHANGED ]\n\n");
ThingBuilder thingBuilder = editThing();
ChannelBuilder channelBuilder;
String[] switchConfigs = { config.switch01 };
List<Channel> oldChannels = getThing().getChannels();
List<Channel> newChannels = new ArrayList<>();
for (int i = 0; i < oldChannels.size(); i++)
Channel oldChannel = oldChannels.get(i);
if (switchConfigs[i].equals("Switchable"))
channelBuilder = ChannelBuilder.create(oldChannel.getUID(), "Switch");
else if (switchConfigs[i].equals("Dimmable"))
channelBuilder = ChannelBuilder.create(oldChannel.getUID(), "Dimmer");
channelBuilder.withLabel(oldChannel.getLabel()).withDescription(oldChannel.getDescription())
.withType(oldChannel.getChannelTypeUID()).withConfiguration(oldChannel.getConfiguration())
.withProperties(oldChannel.getProperties()).withDefaultTags(oldChannel.getDefaultTags())
.withKind(oldChannel.getKind());
thingBuilder.withoutChannel(oldChannel.getUID());
newChannels.add(channelBuilder.build());
updateThing(thingBuilder.withChannels(newChannels).build());
@Override
public void handleConfigurationUpdate(@NonNull Map<@NonNull String, @NonNull Object> configurationParameters)
logger.debug("\n\n[ APL SMART SWITCH HANDLING CONFIG UPDATE ]\n\n");
Configuration configuration = editConfiguration();
for (Entry<String, Object> configurationParameter : configurationParameters.entrySet())
configuration.put(configurationParameter.getKey(), configurationParameter.getValue());
dispose();
updateConfiguration(configuration);
config = configuration.as(SmartSwitchConfiguration.class);
initialize();
@Override
public void initialize()
logger.debug("\n\n[ APL SMART SWITCH INITIALIZE ]\n\n");
thingStructureChanged();
updateStatus(ThingStatus.ONLINE);
