Platform information:
Hardware: RPi4 8GB ram
OS: Rpi OS
openHAB version: 4.3.2
Issue of the topic:
Probably a noob question but I am running openHAB and the OS on one SD card and the Amanda backup on a separate SD Card as recommended.
I know these SD cards don’t last forever and I’m not sure what to do in case of a failure.
If the SD card holding the OS and openHAB completely fails, does the backup SD card (that Amanda writes to) contain a mirror of the OS SD card where I could just swap them out and replace the backup card?
I am including a daily backup email below for more info.
Your advice is appreciated!
Hostname: openhabian
Org : openHABian openhab-dir
Config : openhab-dir
Date : March 25, 2026
These dumps were to tape openhab-dir-14.
The next 10 tapes Amanda expects to use are: openhab-dir-15, openhab-dir-01, openhab-dir-02, openhab-dir-03, openhab-dir-04, openhab-dir-05, openhab-dir-06, openhab-dir-07, openhab-dir-08, openhab-dir-09.
STATISTICS:
Total Full Incr. Level:#
Estimate Time (hrs:min) 0:00
Run Time (hrs:min) 0:01
Dump Time (hrs:min) 0:01 0:00 0:00
Output Size (meg) 312.7 312.6 0.0
Original Size (meg) 342.2 341.9 0.3
Avg Compressed Size (%) 91.4 91.5 7.4
DLEs Dumped 3 1 2 1:2
Avg Dump Rate (k/s) 10060.8 10838.2 11.4
Tape Time (hrs:min) 0:00 0:00 0:00
Tape Size (meg) 312.7 312.6 0.0
Tape Used (%) 15.6 15.6 0.0
DLEs Taped 3 1 2 1:2
Parts Taped 3 1 2 1:2
Avg Tp Write Rate (k/s) 10964.9 11039.6 130.0
USAGE BY TAPE:
Label Time Size % DLEs Parts
openhab-dir-14 0:00 320175K 15.6 3 3
NOTES:
planner: Last full dump of openhabian:/boot on tape openhab-dir-08 overwritten on this run.
planner: Last full dump of openhabian:/etc on tape openhab-dir-13 overwritten in 1 run.
planner: Last full dump of openhabian:/var/lib/openhab on tape openhab-dir-07 overwritten on this run.
taper: tape openhab-dir-14 kb 320176 fm 3 [OK]
DUMP SUMMARY:
DUMPER STATS TAPER STATS
HOSTNAME DISK L ORIG-KB OUT-KB COMP% MMM:SS KB/s MMM:SS KB/s
openhabian /boot 1 40 3 7.5 0:01 2.7 0:00 30.0
openhabian /etc 1 310 23 7.4 0:01 19.6 0:00 230.0
openhabian /var/lib/openhab 0 350060 320149 91.5 0:30 10838.0 0:29 11039.6
(brought to you by Amanda version 3.5.1)
