Sory, maybe a stupid question, but where do i see what version of OH im using, im on ubuntu machine…
Also, how to update to latest ?
Thnx !
Thnx !
In a browser, and assuming it’s running on the same machine, go to localhost:8080
. Your version will show along the bottom of the screen.
To update depends on how you installed it - how did you install openHAB?
Hi
If you want to know the exact version, one method is to log into the openHAB2 console, as the version is shown in the welcome message.
I believe the very latest version is
2.5.7-1
Another trick that I’ve just learnt is this
Try
apt-cache policy openhab2
{ or any other package }
Which will show you something like
Ah yes thnx, i was there, but didnt look down
I installed it with apt
Thanks !
Ok, managed to upgrade it via:
sudo apt-get upgrade openhab2
From what version? Upgrades from versions prior to 2.5 will require other changes.
I had 2.5.1something
Good point
Version 2.4 release notes
I think you meant to link to the 2.5 Release Notes. You linked to 2.4.
Another excellent point
Version 2.5 release notes
Here 2 more ways to find out the version:
xyz@xyz:~$ cat /var/lib/openhab2/etc/version.properties
openHAB Distribution Version Information
build-no : Release Build
online-repo : https://openhab.jfrog.io/openhab/libs-release
Repository Version
openhab-distro : 2.5.7
openhab-core : 2.5.0
openhab1-addons : 1.14.0
openhab2-addons : 2.5.7
karaf : 4.2.7
xyz@xyz:~$ openhab-cli info
Version: 2.5.7 (Build)
User: openhab (Active Process 1450)
User Groups: openhab tty dialout audio
Directories: Folder Name | Path | User:Group
OPENHAB_HOME | /usr/share/openhab2 | openhab:openhab
OPENHAB_RUNTIME | /usr/share/openhab2/runtime | openhab:openhab
OPENHAB_USERDATA | /var/lib/openhab2 | openhab:openhab
OPENHAB_CONF | /etc/openhab2 | openhab:openhab
OPENHAB_LOGDIR | /var/log/openhab2 | openhab:openhab
OPENHAB_BACKUPS | /var/lib/openhab2/backups | root:root
URLs: http://192.168.137.29:8080
https://192.168.137.29:8443
That is the only way that we were told would work for 2.5.1. The Web UI still said 2.5.0.
