I’ve hundreds of lines of playbooks and Ansible is a whole ecosystem as big and as complex as openHAB in many ways. So I’ll show just a couple of my playbooks.
First I’ll say that I literally make zero changes to any of my servers or RPis unless it’s through Ansible. Thus every configuration change, every software install, everything at all get’s captured, saved, and the history tracked in git. I never have to think back to “how did I do that? What was installed on that machine?”
Here is my openHAB playbook.
- name: Change openhab group to 9001
group:
gid: 9001
state: present
system: yes
become: yes
- name: Create openhab user
user:
comment: 'openHAB'
createhome: no
shell: /bin/false
state: present
system: yes
uid: 9001 # uid of openhab user inside the official container
group: openhab
become: yes
- name: Add the openhab user to the dialout group
command: usermod -a -G dialout openhab
become: yes
- name: Add {{ share_user }} to the openhab group
command: usermod -a -G openhab {{ share_user }}
become: yes
- name: Set permissions on openhab data folder so we can check out into it
file:
path: "{{ openhab_data }}"
state: directory
owner: openhab
group: openhab
mode: u=rwx,g=rwx,o=rx
become: yes
- name: Checkout openhab config
git:
repo: "{{ openhab_conf_repo }}"
dest: "{{ openhab_data }}"
accept_hostkey: yes
become: yes
- name: Change ownership of openhab config
file:
owner: openhab
group: openhab
recurse: yes
become: yes
- name: Create expected folders if they don't already exist
file:
path: "{{ item }}"
state: directory
owner: openhab
group: openhab
become: yes
become_user: openhab
with_items:
- "{{ openhab_data }}/conf"
- "{{ openhab_data }}/userdata"
- "{{ openhab_data }}/addons"
- "{{ openhab_data }}/.java"
- name: Create database
influxdb_database:
hostname: "{{ influxdb_ip_address }}"
database_name: "{{ openhab_influxdb_database_name }}"
state: present
username: admin
password: "{{ influxdb_admin_password }}"
# TODO there is currently a bug which prevents us from using influx in the container
# command: influx -username admin -password {{ influxdb_admin_password }} -database '{{ openhab_influxdb_database_name }}' -execute "CREATE USER {{ influx_openhab_user }} WITH PASSWORD '{{ influx_openhab_password }}'"
command: curl -XPOST http://localhost:8086/query?db={{ openhab_influxdb_database_name }}&u=admin&p={{ influxdb_admin_password }} --data-urlencode "q=CREATE USER {{ influx_openhab_user }} WITH PASSWORD '{{ influx_openhab_password }}'"
- name: Give openhab permissions on openhab db
# command: influx -username admin -password {{ influxdb_admin_password }} -database '{{ openhab_influxdb_database_name }}' -execute "GRANT ALL ON {{ openhab_influxdb_database_name }} TO {{ influx_openhab_user }}"
command: curl -XPOST http://localhost:8086/query?db={{ openhab_influxdb_database_name }}&u=admin&p={{ influxdb_admin_password }} --data-urlencode "q=GRANT ALL ON {{ openhab_influxdb_database_name }} TO {{ influx_openhab_user }}"
- name: Create grafana user
# command: influx -username admin -password {{ influxdb_admin_password }} -database '{{ openhab_influxdb_database_name }}' -execute "CREATE USER {{ influx_grafana_user }} WITH PASSWORD '{{ influx_grafana_password }}'"
command: curl -XPOST http://localhost:8086/query?db={{ openhab_influxdb_database_name }}&u=admin&p={{ influxdb_admin_password }} --data-urlencode "q=CREATE USER {{ influx_grafana_user }} WITH PASSWORD '{{ influx_grafana_password }}'"
- name: Give grafana read permissions on openhab_db
# command: influx -username admin -password {{ influxdb_admin_password }} -database '{{ openhab_influxdb_database_name }}' -execute "GRANT READ ON {{ openhab_influxdb_database_name }} TO {{ influx_grafana_user }}"
command: curl -XPOST http://localhost:8086/query?db={{ openhab_influxdb_database_name }}&u=admin&p={{ influxdb_admin_password }} --data-urlencode "q=GRANT READ ON {{ openhab_influxdb_database_name }} TO {{ influx_grafana_user }}"
- name: Update openHAB docker
docker_container:
detach: True
devices:
- "/dev/ttyUSB0:/dev/ttyUSB0:rwm"
- "/dev/ttyUSB1:/dev/ttyUSB1:rwm"
env:
# EXTRA_JAVA_OPTS: "-Xbootclasspath/a:/openhab/conf/automation/jython/jython-standalone-2.7.0.jar -Dpython.home=/ope
nhab/conf/automation/jython -Dpython.path=/openhab/conf/automation/lib/python"
CRYPTO_POLICY: unlimited
hostname: argus.koshak.net
image: "{{ openhab_version }}"
log_driver: syslog
network_mode: host
pull: True
recreate: True
restart: True
restart_policy: always
tty: yes
volumes:
- /etc/localtime:/etc/localtime:ro
- /etc/timezone:/etc/timezone:ro
- "{{ openhab_data }}/conf:/openhab/conf"
- "{{ openhab_data }}/userdata:/openhab/userdata"
- "{{ openhab_data }}/addons:/openhab/addons"
Stuff in {{ }} are variables pulled in from another file. This playbook
- creates and makes sure the openhab Group exits and has the GID of 9001
- creates an openhab user with a uid of 9001
- update the groups the openhab user belongs to
- creates and sets the permissions for the folder where the configs are stored
- check out the config from my personal git server into the config folder (this includes both conf and userdata)
- fix the ownership of the checked out files (I probably don’t need this, I can check it out as the openhab user in the first place)
- create the userdata, conf, and addons folder, I’ve been using this playbook for a long time and I don’t need the .java folder any more, it’s a hold over from the Nest v1 binding
- configure InfluxDB database so OH has a place for persistence
- configure the InfluxDB so the grafana user has access to the openhab database in InfluxDB
- finally, download and start openHAB using Docker.
Here’s my Mosquitto playbook.
- name: Create mosquitto user
user:
comment: 'Mosquitto'
createhome: no
shell: /bin/false
state: present
system: yes
become: yes
- name: Mount mosquitto from file share
include_role:
vars:
mount_mode: '0660'
cifs_user: "{{ share_user }}"
cifs_pass: "{{ share_pass }}"
cifs_domain: "{{ workgroup }}"
mount_user: "mosquitto"
mount_path: "{{ mosquitto_data }}"
mount_src: "{{ mosquitto_mount }}"
- name: Create mosquitto directories
file:
path: "{{ item }}"
state: directory
become: yes
become_user: mosquitto
with_items:
- "{{ mosquitto_data }}/config"
- "{{ mosquitto_data }}/data"
- "{{ mosquitto_data }}/log"
- name: Copy the prepared mosquitto.conf
copy:
src: mosquitto.conf
dest: "{{ mosquitto_data }}/config/mosquitto.conf"
mode: u=rw,g=rw,o=r
become: yes
- name: Install mosquitto cients, temporarily install mosquitto
apt:
name: "{{ item }}"
update_cache: no
become: yes
with_items:
- mosquitto
- mosquitto-clients
- openssl
- name: Install pexpect
pip:
become: yes
- name: Generate passwd file
expect:
command: mosquitto_passwd -c {{ mosquitto_data }}/config/passwd {{ mosquitto_user }}
responses:
'Password\:' : "{{ mosquitto_passwd }}"
'Reenter password\:' : "{{mosquitto_passwd }}"
become: yes
- name: Remove mosquitto
apt:
update_cache: no
purge: yes
state: absent
become: yes
- name: Recreate mosquitto user
user:
createhome: no
shell: /bin/false
state: present
system: yes
become: yes
- name: Does the CA already exist?
stat:
path: "{{ mosquitto_data }}/config/ca.crt"
register: mosquitto_ca
- name: Create mosquitto certificate authority
expect:
command: openssl req -new -x509 -days 1461 -extensions v3_ca -keyout {{ mosquitto_data }}/config/ca.key -out {{ mosquitto_data }}/config/ca.crt
responses:
'Enter PEM pass phrase\:' : "{{ mosquitto_ca_passwd }}"
'Verifying \- Enter PEM pass phrase\:' : "{{ mosquitto_ca_passwd }}"
'Country Name \(2 letter code\) \[AU\]\:' : "{{ mosquitto_ca_country }}"
'State or Province Name \(full name\) \[Some\-State\]\:' : "{{ mosquitto_ca_state }}"
'Locality Name \(eg, city\) \[\]\:' : "{{ mosquitto_ca_city }}"
'Organization Name \(eg, company\) \[Internet Widgits Pty Ltd\]\:' : "{{ mosquitto_ca_org }}"
'Organizational Unit Name \(eg, section\) \[\]\:' : "{{ mosquitto_ca_unit }}"
'Common Name \(e\.g\. server FQDN or YOUR name\) \[\]\:' : "{{ mosquitto_ca_fqdn }}"
'Email Address \[\]\:' : "{{ mosquitto_ca_email }}"
when: mosquitto_ca.stat.islnk is not defined
become: yes
- name: Create server key and cert
include_role:
vars:
key: "{{ mosquitto_data }}/config/server.key"
csr: "{{ mosquitto_data }}/config/server.csr"
crt: "{{ mosquitto_data }}/config/server.crt"
cert_country: "{{ mosquitto_ca_country }}"
cert_state: "{{ mosquitto_ca_state }}"
cert_city: "{{ mosquitto_ca_city }}"
cert_org: "{{ mosquitto_ca_org }}"
cert_unit: "{{ mosquitto_ca_unit }}"
cert_fqdn: "{{ mosquitto_ca_fqdn }}"
cert_email: "{{ mosquitto_ca_email }}"
ca_crt: "{{ mosquitto_data }}/config/ca.crt"
ca_passwd: "{{ mosquitto_ca_passwd }}"
ca_key: "{{ mosquitto_data }}/config/ca.key"
become: yes
- name: Get uid
command: id -u mosquitto
register: mosquitto_uid
- name: Get gid
command: id -g mosquitto
register: mosquitto_gid
- name: Run the eclipse-mosquitto docker container
docker_container:
detach: True
exposed_ports:
- 1883
- 9001
- 8883
hostname: mosquitto.koshak.net
image: eclipse-mosquitto
log_driver: syslog
published_ports:
- "1883:1883"
- "9001:9001"
- "8883:8883"
recreate: True
restart: True
state: started
user: 999 # TODO why can't I use the variable created above?
volumes:
- /etc/passwd:/etc/passwd:ro
- /usr/share/zoneinfo:/usr/share/zoneinfo:ro
- "{{ mosquitto_data }}/config:/mosquitto/config"
- "{{ mosquitto_data }}/log:/mosquitto/log"
- "{{ mosquitto_data }}/data:/mosquitto/data"
This playbook
- creates a mosquitto user
- mounts the mosquitto data folder from my NAS using CIFS (this is all handled by another role), I need to change this to NFS really
- create the mosquitto folders if they don’t exist
- I’ve a precreated mosquitto.conf file that I use that is part of the playbook, so I copy that over to the machine (the playbook assumes that the CIFS mount is empty)
- temporarily install mosquitto on the host so I can more easily create the passwd file for the Mosquitto authentication
- creates the CA and certs for encrypted Moquitto connections
- finally, download and start up the Mosquitto in Docker
All of these above playbooks are put into a special directory structure called roles. So at the top level I can create a file that tells Ansible what to run on a given host. So my home-auto.yml file is
# Prerequisites:
# - install ssh
# - set up ssh for certificate only logins
# - install python
# TODO set up root with ssh certs for git interactions
- hosts: homeauto
roles:
- common
- fish
- mount-home
- vm
- docker
- msmtp
- openzwave
- openhab
- grafana
- screengrab
- share-ohconf
- multitail
- glances
- sensorreporter
- tripwire
So, if I were to want to build a new home-auto machine from scratch I just need to update the inventory to tell Ansible that the new machine is a home-auto machine, do the minimal prerequisites (make it so we can ssh and that Python is available on the host) and run ansible-playbook home-auto.yml
and wait. In the end I’ll have an identically configured home-auto machine.
