When do props passed to a component: widget:widget_anywidget get evaluated
Hi everyone,
I am currently working on an widget for the Viessmann-Binding, in principle i got it fully working.
But i stumpled upon this:
                  slots:
                    default:
                      - component: widget:wp_Tab2
                          heatGroup: =props.groupItem
                          firstCircuit: =Number((@(props.groupItem+'_Circuits_enabled')).replace(/[\[\]\"]/g,'').split(',')[0])
                          lang: =(dayjs().format('dddd').includes('day'))
                          HeatColorScheme: =props.colorScheme
The widget is build from one Main Widget-Part and lots of functionality is realized in “Sub-Widgets”.
In the code piece above i pass firstCircuit which is the first heating circuit into a subwidget:
I thought that the expression gets evaluated before passing to the widget, but that seems not to be true.
The item is a JSON String that might look like [“0”], or [“1”] but also [“1“,”2”,”3”,”4”].
In the subwidget i need this variable to render the schedule, heating-items etc. and i need the value from the very start of the widget because the items to be used follow naming schemes for example like group+’_Heating_curve_Circuit_1_shift’. for the heating curve shift of circuit 1.
In the sub-widget (only the starting part):
component: f7-block
  class:
    - margin-horizontal-half
    - no-margin-vertical
    - no-padding
  key: =props.firstCircuit
slots:
  default:
    - component: oh-context
        functions:
          circuitsCount: =(x)=>Number(JSON.parse(@(props.heatGroup+'_Circuits_enabled')).length)
        variables:
          selectedCircuit: =props.firstCircuit
      slots:
        default:
          - component: f7-block
              class:
                - no-padding
                - text-align-center
              style:
                display: grid
                font-size: 11px
                font-weight: 700
                gap: 5px
                grid-template-columns: 35px 5fr repeat(3, 4fr)
                line-height: 12px
                margin: 2px 0px 2px 0px
              key: =@(props.heatGroup+"_Heating_schedule_Circuit_"+vars.selectedCircuit)
            slots:
              default:
                - component: Label
                    text: =!props.lang?'Heizk.':'Circuit'
                - component: Label
                    text: =!props.lang?'Betriebsart':'OperatingMode'
                - component: Label
                    text: =!props.lang?'Reduziert':'Reduced'
                - component: Label
                    text: =!props.lang?'Normal':'Normal'
                - component: Label
                    text: =!props.lang?'Komfort':'Comfort'
                - component: oh-button
                    action: variable
                    actionVariable: selectedCircuit
                    actionVariableValue: =((vars.selectedCircuit || 0) >= fn.circuitsCount() - 1)?
                      props.firstCircuit:((vars.selectedCircuit || 0) + 1)
                    outline: true
                    small: true
                    style:
                      background-color: lightgray
                      border-radius: 4px
                      borderColor: =props.HeatColorScheme
                      color: black
                      display: flex
                      font-size: 11px
                      padding-left: 3px
                      padding-right: 3px
                      text-transform: uppercase
                    text: =(vars.selectedCircuit).toString()
I do assign the value to a variable in an oh-context block. Unfortunatly this isn’t working as expected and selectedCircuit throws ‘NaN’.
To solve this problem i added selectedCircuit in the parentBlock as key.
So when the evaluation is finished the widget gets updated and is rendered correctly.
So my question is this intended that the expression is passed as string to the sub-widget or should the evaluated value be passed to widget.
Another observation i made with my widget is that generally JSON.parse results do generally need a serious amount of time.
The widget-code is truncated, but can be seen here :
https://github.com/SePHTaN/semanticHomeMenu/tree/main/heatpump
What version of OH are you using? There have been some recent changes to parts of the MainUI that might be relevant here.
The basic answer, however, is that the most likely source of the issue is not the passing of the props to the child widget. There’s a known timing issue with the first evaluation of the context variables where it cannot access the item states. Any subsequent re-calculations are correct and all item state values can be successfully retrieved by the variables. So, your key workaround is actually one good solution to the problem.
Here’s the issue where this is being discussed, in case you are interested.
Hi Justin,
im currently OH-version:
openHAB 5.1.2
Release Build
Main UI Commit b476d315
I know that 5.1.3 is already there but haven’t had the time to update.
Will test tomorrow, but i believe the only fix relevant for me is the zwave network map.
Thanks for the quick answer, will look into the discussion also tomorrow.
