When I installed Telegram Action the MQTT binding has been uninstalled
Hi just installed the Telegram Action-telegram - 1.12.0.SNAPSHOT
but when that finished I got a message that the action-mqtt action has been uninstalled:
after this message I was able to reinstall the MQTT action again.
2018-02-19 10:13:33.546 [thome.event.ExtensionEvent] - Extension ‘action-telegram’ has been installed.
2018-02-19 10:13:44.532 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection ‘mosquitto’
2018-02-19 10:13:44.647 [INFO ] [core.karaf.internal.FeatureInstaller] - Uninstalled ‘openhab-action-mqtt’
2018-02-19 10:13:44.652 [thome.event.ExtensionEvent] - Extension ‘action-mqtt’ has been uninstalled.
have you defined anything (manually) in your /etc/openhab2/services/addons.cfg ?
anyway: If you don’t use the MQTT-Action: remove it. I don’t know why it would be uninstalled when you installed another action (this shouldn’t happen if you haven’t messed around with addons.cfg)
Ps: OH2 version? platform? JVM?
It’s a known bug. Please report there.
How did you install both? PaperUI, Karaf Console etc.
Hi it looks like the bug @Josar posted here.
ill continue to comment in that post!
thx
