When i try to ssh i get this
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Mon Jul 31 01:02:20 2017 from 10.0.0.44
Every 2.0s: cat /boot/first-boot.log Mon Jul 31 01:09:54 2017
2017-04-10_09:58:56_UTC [openHABian] Starting the openHABian initial setup. This might take a few minutes.
2017-04-10_09:58:56_UTC [openHABian] If you see this message more than once, something went wrong!
2017-04-10_09:58:58_UTC [openHABian] Storing configuration… OK
2017-04-10_09:58:59_UTC [openHABian] Changing default username and password… OK
2017-04-10_09:59:00_UTC [openHABian] Setting up Wifi connection… SKIPPED
2017-04-10_09:59:00_UTC [openHABian] Ensuring network connectivity… OK
2017-04-10_09:59:00_UTC [openHABian] Waiting for dpkg/apt to get ready… OK
2017-07-31_03:48:44_UTC [openHABian] Updating repositories and upgrading installed packages… OK
2017-07-31_04:15:55_UTC [openHABian] Installing git package… OK
2017-07-31_04:17:30_UTC [openHABian] Cloning myself… OK
2017-07-31_04:17:32_UTC [openHABian] Executing 'openhabian-setup.sh unattended’
2017-07-31_04:17:32_UTC [openHABian] Checking for root privileges… OK
2017-07-31_04:17:32_UTC [openHABian] Loading configuration file ‘/etc/openhabian.conf’… OK
2017-07-31_04:17:32_UTC [openHABian] Setting timezone based on IP geolocation… OK (America/New_York)
2017-07-31_00:19:59_EDT [openHABian] Setting locale based on openhabian.conf… OK
2017-07-31_00:20:41_EDT [openHABian] Setting hostname of the base system… OK
2017-07-31_00:20:41_EDT [openHABian] Setting the GPU memory split down to 16MB for headless system… OK
2017-07-31_00:20:41_EDT [openHABian] Installing basic can’t-be-wrong packages (screen, vim, …)… OK
2017-07-31_00:28:56_EDT [openHABian] Installing additional needed packages… OK
2017-07-31_00:29:27_EDT [openHABian] Installing additional bluetooth packages… OK
2017-07-31_00:30:22_EDT [openHABian] Adding slightly tuned bash config files to system… OK
2017-07-31_00:30:22_EDT [openHABian] Adding slightly tuned vim config file to system… OK
2017-07-31_00:30:22_EDT [openHABian] Downloading and setting up FireMotD… OK
2017-07-31_00:31:07_EDT [openHABian] Installing etckeeper (git based /etc backup)… OK
2017-07-31_00:32:24_EDT [openHABian] Installing Zulu Embedded OpenJDK… OK
2017-07-31_00:38:22_EDT [openHABian] Installing openHAB 2.1 (stable)… OK
ssh from what machine to what machine?
How did you install?
What is the exact ssh command?
What are you trying to accomplish through this ssh?
While in this case it isn’t a problem, it is much easier to read code and logs when they are surrounded by code fences in your postings:
code or logs go here
