Per http://docs.openhab.org/tutorials/beginner/uis.html and many other images on the tutorial sites, there are multiple references to Setup Wizard. However, on my new installation I don’t have any such option. Has this been removed?
This? http://docs.openhab.org/configuration/packages.html
You should see it upon first connection
Thanks for the quick reply! I created a fresh install:
$ mkdir openhab
$ cp openhab-offline-2.0.0-SNAPSHOT.zip openhab/
$ cd openhab; unzip openhab*zip
$ ./start.sh
Upon connecting to http://server:8080 I’m asked to select a package. I chose standard package. Here is the following page (note: no Setup Wizard)
Have I missed a step? Thanks!
I’m still not sure what’s the “Setup Wizard” you are looking for. Everything looks fine. You are looking at PaperUI, if you want to switch to BasicUI or HABmin, just browse to http://server:8080 (without a trailing path)
Looks like an old image that refers to the inbox as a “Setup Wizard”.
“Inbox” is what was called “Setup Wizard”, when you add bindings via the “add-ons” screen, you can search for Things in the inbox to set up Things and in turn their channels and items.
Great to know. Thanks @Benjy
