I know I can edit the servier-side config for HABpanel using: PaperUI->Services->UI->HABPanel or openhab> config:edit org.openhab.habpanel (actually the latter doesnt work)
Where is the JSON config file for a Panel setting , for HABPanel, on “my server” (/srv/openhab2 on my machine)
Yes Rich, that’s the issue for me, I’m trying to find the JSON version , similar to the local (on device) config file which is JSON and can be edited.
Reason I ask is that I’ve created a dashboard in the panel that uses a lot of widgets and I want to cut and paste to create other dashboards and tweak the linked items.
Like I say, I can only see -as you say - the binary (or might well as be) versions under my /srv directory.
Fixed it. using Android phone OH app, I just saved it locally , exported to a file, went to OH and a PC, imported the file, edited locally and then saved to the server. Back on the phone i selected the server config. All good.
