Where is the Zigbee-configuration stored?
Hi
I am running Openhabian/Rpi with a Sonoff Zigbee 3.0 USB Dongle Plus as coordinator.
Is it correctly understood that the config-data for the zigbee-setup is not stored on the coordinator itself when the system is shut down?
If yes, then it probably means that if you shut down the Rpi, and replaces the coordinator witn another corresponding coordinator then every runs again after restart?
Thanx in advance.
Torben
/var/lib/openhab/jsondb/org.openhab.core.thing.Thing.json - search pattern: zigbee:
I tend to agree. @chris, could you confirm?
