I am using the Zigbee binding and finding out a few devices I own are supported perfectly or with slight differences. Where should I report such new working devices for the Zigbee binding, including small problems ?
For example the IKEA control outlet is detected as a dimmer, but can’t be used as such. When changing it category and type to Switch it behaves accordingly.
Another example, Gledopto GL-B-007Z is detected and works fine, including proper color controls.
Since you are running Milestone 5, it should already have the latest binding without needing a manual install.
Generally people only use the manual installation to get support for additional devices or to correct other issues.
