i want to edit the HTML Template of habpanel, i mean the source html file of it. but i cant find the directory on my raspberry where this file is stored… does anybody can help me and tell me the location of the file? I am also searching for the html files of paperUI and classicUI if anyone knows the locations of there html files this would also be helpful.
in my browser if i access my habpanel i see the path http:ip_adress:8080/start/index.html
But i cant find a start folder containing a index html file.
it would very helpful if someone can post the locations/directories
hmm okay i hoped, because of angular is a client side rendering framework, that there is a possibility to access the html files. i thought about editing these html files to create a “little” bit of user login etc. but as you say its just on the fly than there might be no way of doing this without touching the php scripts. thank you
but what about the openHab user provided static content folder?
Like http://device-address:8080/static/index.png
where it is possible to serve a html file through the HTTP server of openHAB.
i have a few questions to this:
1)is it possible to serve a angular application out of this folder ?
2)if yes, is there a way to access items out of this application without using mqtt services or else?
