I have a number of thermostats grouped together like this:
Group All_Heaters "All Heaters" <heating>
Number Bedroom_Heater "Bedroom Heater [%.1f °C]" <heating> (All_Heaters) {zwave="13:0" }
Number Living_Room_Heater_1 "Living Room Heater 1 [%.1f °C]" <heating> (All_Heaters) {zwave="9:0" }
Number Living_Room_Heater_2 "Living Room Heater 2 [%.1f °C]" <heating> (All_Heaters) {zwave="10:0" }
Number Hall_Heater "Hall Heater [%.1f °C]" <heating> (All_Heaters) {zwave="11:0" }
Number Bathroom_Heater "Bathroom Heater [%.1f °C]" <heating> (All_Heaters) {zwave="14:0" }
Then I have the following in my sitemap to turn them all on/off.
Switch item=All_Heaters mappings=[15="All Off",22="All On"]
This works fine, but I don’t like the fact that I have numbers 15 and 22 hardcoded in my sitemap. This means that if I want to change them, I have to edit that file.
I would like to have two more Number items defined which will be called Heaters_Temp_On and Heaters_Temp_Off which will hold these two values. This way I can also add them in a sitemap and change their values with the mobile app. However, I don’t know how to use them in the sitemap. Do I need to write rules for this? Do you have any better idea?
