I have a general question about the remote openHAB binding: Which item types are supported by the remote openHAB binding?
I have installed it on two instances. After that I created respectively a thing for each server. In the end I have on both sides more trigger channels than items. So I can not link each channel to the item. It doesn’t matter now whether I try to link this via the Thing from the remote openHAB binding or via an item and add a channel there. Neither works.
I suspect that only switch items will work. However, there is nothing in the documentation about this.
On both instances I have as example following items:
Group gIoT_Hue_Lampe6 "Lampe 6" <lightbulb> (gIoT_WandLampen)
Switch iIoT_Hue_Lampe6_Schalter "Schalter" <light> (gIoT_Hue_Lampe6) {channel="hue:0210:00178825916e:23:color"}
Color iIoT_Hue_Lampe6_Farbe "Farbe" <colorwheel> (gIoT_Hue_Lampe6) {channel="hue:0210:00178825916e:23:color"}
Dimmer iIoT_Hue_Lampe6_Helligkeit "Helligkeit" <light> (gIoT_Hue_Lampe6) {channel="hue:0210:00178825916e:23:color"}
Dimmer iIoT_Hue_Lampe6_Farbtemperatur "Farbtemperatur" <rgb> (gIoT_Hue_Lampe6) {channel="hue:0210:00178825916e:23:color_temperature"}
String iIoT_Hue_Lampe6_Alarm "Alarm" <alarm> (gIoT_Hue_Lampe6) {channel="hue:0210:00178825916e:23:alert"}
Switch iIoT_Hue_Lampe6_Farbeffekt "Farbeffekt" <colorwheel> (gIoT_Hue_Lampe6) {channel="hue:0210:00178825916e:23:effect"}
If I try to link the channel I have as example:
Item iIoT_Hue_Lampe6_Helligkeit
remoteopenhab:server:192_168_0_22:iIoT_Hue_Lampe6_Helligkeit (Dimmer)
Item iIoT_Hue_Lampe6_Helligkeit from the remote server.
Only following items can be linked / discovered:
Farbeffekt (iIoT_Hue_Lampe6_Farbeffekt)
Schalter (iIoT_Hue_Lampe6_Schalter)
So only the switch items can be found. It is only a simple example.
Thanks in advance.
