I’m trying to figure out how the iCalendar binding is used by the community to decide how critical a breaking change would be. That does not mean there won’t be breaking changes but it maybe helps to get a different point of view as you clearly don’t want to change your configuration often. Please do not choose items you like to use in future.
I do use event filtering and my favorite enhancement would be the current event presence for the filtered events
I am not sure what is meant by “calendar metadata”, thus most probably do not use this
thanks for the info, then actually I do use this My calendar provider is a bit shaky and I use this to notify me if update failed for a while (this was mainly needed when there was this issue with the http connection which is resolved now but my check is still in place)
rfuh
in the EventFilter there is the possibility to filter on the following fields:
Description/Content
comment
Contact
location
Unfortunately there is no event channel for this information.
Is there another way to access this information? or possibly planned to add channels in the binding for this?
A trigger for notifications before the event starts would also be a nice feature.
Regards Ulf
Currently, there is no way to retrieve information about events other than you know. The PR above includes already that information for live events. However i did not get feedback, so it’s in the state of mid-november and surely needs to get rebased and recompiled to run on a current daily build. I currently can’t rebase it as my computer for such work is physically broken and my daily driver is not able to do that.
