What is the correct openhab-cli (or Karaf) command to install a binding?
I used:
feature:install openhab-binding-openweathermap
I see that the binding is started for a few seconds:
openhab> feature:list | grep -i openweather
openhab-binding-openweathermap │ 2.5.0 │ x │ Started │ openhab-addons-2.5.0 │OpenWeatherMap Binding
But then I got errors in the openhab.log:
Could not update element with key openweathermap:weather-and-forecast:api:local in ManagedThingProvider, because it does not exists.
… and the binding stops, about 10 seconds later than I gave the install command.
When I install OpenWeatherMaps using the PaperUI, it works perfectly
The same seems to happen when I try to install Chris’ Zwave binding.
Other bindings like Pushover or Telegrams work fine using feature:install
Anyone know what I miss here?
I’m using OH 2.5.0 via Openhabian on a Rasperry Pi 3.
Thanks in advance!
