Why have my rules stopped running?
Okay as a summing up solution for the issue, I have Here the steps to follow when your rules stopped working. Thanks to @rlkoshak @chris @Bruce_Osborne @rossko57
  1. read the guide for rules: (OH 1.x and OH 2.x Rules DSL only] Why have my Rules stopped running? Why Thread::sleep is a bad idea - #5 by rlkoshak (only applies for OpenHab 2.5, and no longer required in 3.0)
  2. make sure that your trigger runs by checking events.log. If you use z-wave, make sure that you have the report group 1 setup to basic or multilevel-switch reports and associated with the controller. Do not use hail cc
  3. If you copy some rules, make sure to keep names different! If you don’t, one rule may exclude the other from running (figured this out yesterday after weeks of searching! So be careful with names when you have many different rules)
If someone has another point to add/modify, feel free to post, and I’m gonna edit this :slight_smile:
