In the beginning I recognized that the openhab time (I use ntp) is 1 hr off.
Now in daylight savings in EU it’s ok. Only the request.log has a different time.
I tried the suggestion below, but it did not change the one hour offset.
So my general question: When I use openhab on my raspi, why do I need an openhab ntp, if I have a systems ntp daemon running?
In general, you shouldn’t need to use the openhab NTP binding if the host operating system time is synchronized with an NTP server. I don’t know why your request log would be an hour different.
In the OH2 version of the ntp binding there are less ntp requests done. It keeps for the intermediate updates the systemtime + delta from the last ntp check. In case you have a ntp deamon running the delta will always be zero I assume
