Hi to all
when i run this code
rule "Scendi"
//Every weekday at 21:19 hours
Time cron "30 44 10 ? * MON-SUN *"
logWarn("Alarm", "The {} all'inizio", LivingRoom_Light2.state)
var Number y = 0
var Number k = 0
if (LivingRoom_Light2.state == ON) {
logWarn("Alarm", "The {} dentro", LivingRoom_Light2.state)
createTimer(now.plusSeconds(24)) [|
Auto.postUpdate(0)
LivingRoom_Light1.sendCommand(ON)
//controlla se la serranda è già per un pò abbassata e calcola di quanto
//la deve ancora abbassare
y = (Percentuale.state).intValue
Percentuale2.postUpdate(y)
logWarn("Alarm", "The {} valore di y in ap automat.", Percentuale.state)
createTimer(now.plusSeconds(y)) [|
LivingRoom_Light1.sendCommand(OFF)
Percentuale.postUpdate(0)
return;
if (LivingRoom_Light2.state == OFF) {
Auto.postUpdate(0)
//dire Auto.postUpdate(0) significa dire che Auto.state == 0. con i numeri si scrive cosi
// logWarn("Alarm", "The {} dopo messo a 0", Auto.state)
// update item to switch on light here
y = (Percentuale.state as Number).intValue
Precisione.postUpdate(0)
i have this error:
2019-03-24 10:44:33.249 [ome.event.ItemCommandEvent] - Item ‘LivingRoom_Light1’ received command ON
2019-03-24 10:44:33.252 [WARN ] [eclipse.smarthome.model.script.Alarm] - The 6 valore di y in ap automat.
2019-03-24 10:44:33.266 [vent.ItemStateChangedEvent] - Auto changed from 1 to 0
2019-03-24 10:44:33.339 [vent.ItemStateChangedEvent] - LivingRoom_Light1 changed from OFF to ON
2019-03-24 10:44:33.352 [vent.ItemStateChangedEvent] - Auto changed from 0 to 1
2019-03-24 10:44:33.359 [WARN ] [eclipse.smarthome.model.script.Alarm] - Quanto vale Percentuale parte 2? 6
2019-03-24 10:44:33.363 [WARN ] [eclipse.smarthome.model.script.Alarm] - Quanto vale z? 6
2019-03-24 10:44:33.374 [vent.ItemStateChangedEvent] - Percentuale changed from 6 to 0
2019-03-24 10:44:39.265 [ome.event.ItemCommandEvent] - Item ‘LivingRoom_Light1’ received command OFF
2019-03-24 10:44:39.263 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.2019-03-24T10:44:39.256+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
<XFeatureCallImplCustom>.sendCommand(<XFeatureCallImplCustom>)
<XFeatureCallImplCustom>.postUpdate(<XNumberLiteralImpl>)
} ] threw an unhandled Exception:
java.lang.reflect.UndeclaredThrowableException: null
at com.sun.proxy.$Proxy151.apply(Unknown Source) ~[?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
Caused by: org.eclipse.smarthome.model.script.engine.ScriptExecutionException: The name ‘Precisione’ cannot be resolved to an item or type; line 58, column 4, length 10
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:141) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:902) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:865) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:224) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:204) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:768) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:220) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:447) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:228) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:190) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
… 4 more
2019-03-24 10:44:39.383 [ome.event.ItemCommandEvent] - Item ‘LivingRoom_Light1’ received command OFF
2019-03-24 10:44:39.356 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.2019-03-24T10:44:39.256+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
Caused by: java.lang.reflect.UndeclaredThrowableException
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
… 1 more
… 1 more
2019-03-24 10:44:39.433 [vent.ItemStateChangedEvent] - LivingRoom_Light1 changed from ON to OFF
I use this code to commanda a shutter. I set a time and in that moment automatically the rule actives the shutter.
The rule works well but i have this error
