All,
Just a quick one:
I am currently migrating from 2.5-x to 3.0 and it works perfectly smooth with the new UI
So, thanks a million to all the contributors!
Because I touch the system significantly anyway I wonder if I should change all Number items to use units (e.g. Number:Temperature
I use some of these already, but struggeled a lot when it came to number comparison (temperature >= xx).
So the simple question is:
Is there any other advantage of using units globally other than I can save time not to manually put °C into Habpanel etc.? (which I already did)
Without the units comparisons are much easier.
Thanks in advance.
