To answer my own question in the case someone is looking für the same thing.
It is possible to change the max and the min values of the temperature-axis by adding a single parameter into the yAxis-Block of the widget.
@B0rner & @Hamlet
Thanks for this update, I would be interested to put a defined scale for the temperature.
My purpose is to have a chart for the outdoor temperature giving the lowest expected (-5 °C) and the highest expected (+35 °C). With such a fixed scale I can see from the graph the current temperature niveau and also the variation within this niveau.
Autoscaling will always show a variance even it is only in a smal range …
